need Info about Kern VARIO-SWITAR 1:1,9 f16-100mm POE BOLEX H16RX zoom lens
#1 Giovanni Savino
Giovanni Savino
  • 11 posts
Posted 15 October 2006 - 05:02 PM
I need to use this lens on a Bolex REX 5 but there are a couple of things I am unsure about:
there is a small push button to run the camera from the lens body right below the screw-in hole to attach the "remote" start stop cable.
This push button can be swung to the left and to the right against two small symbols ( two circles, one with a small black dot and the other with a big black dot in it) and appears to affect the built in metering.
All info about how to use this properly would be greately apreciated.
Thank You
#2 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 15 October 2006 - 05:47 PM
Thank You
The POE has a two blade servo iris mechanism - I think you can set a preset iris so when you start shooting it will go to that setting immediately (keeping the iris open for viewing the brighter image when not shooting) - this switch will be related to that somehow...
There is a manual or at least a brochure here:
http://www.apecity.com/manuals/ :)
This question is related to 16mm cinematography - I think you would get much better replies if you put (both) of your threads in there ... :rolleyes:
