Question on Arri 16BL lens mount
#1 Mark A. Rapp
Mark A. Rapp
  • 59 posts
Posted 18 October 2006 - 05:51 PM
New question for anyone in the know:
Will the lens mount on the Arri 16BL (the bayonet mount) take Arri "standard" lenses as well as bayonet lenses?
I read something online that led me to believe so. The excerpt is this: "...The Bayonet mount is backwards compatible, for mounting ARRI Standard mount lenses..." This leads one to believe that the bayonet mount is engineered to accept lenses built for an Arri "standard" mount. Or am I way off here?
#2 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 18 October 2006 - 06:08 PM
I have never done this on an Arriflex 16BL, so it is possible that I am mistaken, but I have never seen an Arriflex camera with a "bayonet" mount that could not take lenses with the ARRI standard mount. I have done this with the "bayonet" mount on Arriflex 16S/B cameras as well as Arriflex 16SR and 16SRII cameras. I cannot see any reason why the Arriflex 16BL would be any different.
With one caveat. You need to be careful what lens you mount on the front of the Arriflex 16BL because some of the early Schneiders, almost all the Cooke Kinetals, and some of the early Zeiss lenses in ARRI standard mount will go too deep into the BL and hit the mirror. Be very careful in checking if the lens goes to deep, because if you bust the mirror on that camera, it is quite expensive to repair.
Hope that helps,
-Tim
#3 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 18 October 2006 - 07:39 PM
Hi Mark,
Tim is right on regarding the fact that both lens mounts will work. He's also right about the danger of elongated exit pupils possibly hitting the mirror on the lenses mentioned.
Bernie
#4 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 19 October 2006 - 08:10 AM
HI
I own an arriflex bl super 16 bayonet mount.I use an zeiss 10 - 100 bayonet a 16mm distagon bayonet and a 25mm distagon bayonet In standard mount lenses i use zeiss planar 32mm and 59mm and a zeiss sonar 85mm from my 2c camera. There is a list of witch standard lenses fits on the camera. Try www.cinematechnic.com\resources\arri_16bl.
NOT ALL STANDARD LENSES FITS ON CAMERA WHEN I WAS STUDENT I DESTROYED A BL 16 USING A SCHNEIDER LENS AND THE MIROR DESTROYED.
Sorry for my English :unsure:
#5 Mark A. Rapp
Mark A. Rapp
  • 59 posts
Posted 19 October 2006 - 02:29 PM
So I'm good with a standard lens as long as it doesn't protrude in to the mount cavity any further than my stock Zeiss zoom. Thanks, all. Much appreciated!
P.S. I covet your BL Super 16... :D
