overexpose/pull
12 replies to this topic
#1 Adam Berra
Adam Berra
  • 4 posts
Posted 22 October 2006 - 11:18 PM
I'm shooting a short on s16, and I plan to shoot on fuji eterna 500T. I am trying to acheive a very smooth look with little detail in the highlights and shadows. My though was to overexpose two stops and pull one. I was curious as to whether anyone had tried something similar with this stock and could provide any insight.
#2 Chris Keth
Posted 22 October 2006 - 11:57 PM
How is that going to achieve your goal of little shadow detail?
#3 David Mullen ASC
  • 20068 posts
Posted 23 October 2006 - 01:07 AM
What do you mean by "little detail"? More detail (less contrast) or less detail (high contrast)? Overexposing and pull-processing a lower-contrast stock like Eterna 500T is only going to make it even lower in contrast.
#4 Tomas Koolhaas
Tomas Koolhaas
  • 334 posts
  • los angeles
Posted 23 October 2006 - 01:21 AM
I just finished a short on super16 on eterna 500T, I overexposed a stop (rated at 250) and pulled a stop.
The Director wanted a very low contrast slightly desaturated pastely look, thats why I did the pull.
I really liked the effect, it gave the highlights a bit of a nice softness to them which I liked as well.
The blacks were pretty milky though so we ended up bringing them down a little bit in certain shots/scenes in telecine (still had a very low con look, but just a bit less milky).
Hope this helps.
Cheers.
#5 andres victorero
andres victorero
  • 412 posts
  • Spain
Posted 23 October 2006 - 07:41 AM
Can you post some frame?
thanks
#6 Adam Berra
Adam Berra
  • 4 posts
Posted 23 October 2006 - 12:22 PM
Sorry I wasn't very specific in what I wanted to do. Tomas, that sounds interesting, it'd be great to see some frames.
#7 Tomas Koolhaas
Tomas Koolhaas
  • 334 posts
  • los angeles
Posted 23 October 2006 - 01:39 PM
err...yeah, the only problem is right now I only have a DVD copy of our Telecine footage, I dont know how to export still frames from a DVD...I know if I could get the DVD footage into a final cut timeline I could do it, but I cant seem to import this DVD into final Cut (I only just started using final cut recently)...If someone could tell me how, I will post many frames on here and be eternaly greateful, as I have wanted to do this for a while but could never figure out how (I know it's possible because I have imported footage from a DVD before but the ones from the telecine house don't seem to work with final cut).
Cheers.
Edited by Tomas Koolhaas, 23 October 2006 - 01:40 PM.
#8 Tomas Koolhaas
Tomas Koolhaas
  • 334 posts
  • los angeles
Posted 24 October 2006 - 04:37 PM
Anyone.....no....oh well, we will just have to wait till I get DVCAM copies then...unless someone can tell me how to import a DVD into final Cut....anyone.....
#9 Sakari Suuronen
Sakari Suuronen
  • 53 posts
  • Tampere, Finland
Posted 26 October 2006 - 07:00 AM
Tomas, I remember brining stuff from dvd to Final Cut through "Mac The Ripper" program. It's free, google it. I remember it was a bit tricky but not impossible.
I'd also like to see your footage.
#10 Rob Featherstone
Rob Featherstone
  • 55 posts
Posted 26 October 2006 - 07:56 AM
There is a great program dvdxdv http://www.dvdxdv.com/ which is not very expensive that can convert dvd files to quicktime. There is also mac the ripper for other reasons. But if it is something you shot I think dvdxdv should do what you want.
-Rob Feathersone
#11 Tomas Koolhaas
Tomas Koolhaas
  • 334 posts
  • los angeles
Posted 26 October 2006 - 11:34 PM
-Rob Feathersone
Cheers guys,
I just got it (DVDxDV), I will give it a shot...If it works..stills will follow, if not...back to the drawing board.
#12 Seamus Mulligan-Ferry
  • 21 posts
  • Brooklyn, NY
Posted 27 October 2006 - 12:01 AM
Cheers guys,
Will snagging a screen capture directly from the DVD work? I know the regular screen capture function is disabled in DVD playback on Macs, but if you download the Capture widget at -
Capture Widget - Apple.com
-you should be able to open dashboard, click on it and capture a paused DVD image (circumventing the disabled screen capture issue). Anyways, might be easier/quicker.
I believe I may have learned this trick from a David Mullen post--One of the many posts full of helpful information he's provided on this site.
#13 Tomas Koolhaas
Tomas Koolhaas
  • 334 posts
  • los angeles
Posted 27 October 2006 - 01:51 AM
Haha I just read that post too late, I already spent an hour converting the DVD to a quicktime,
I have exported some stills but now cant seem to make attachments to my posts....it says O Bytes left before I even make any attachments????
Is it because I am a basic member????
Cheers.
Edited by Tomas Koolhaas, 27 October 2006 - 01:54 AM.
