CLA 35 HD: HD Adapter for 35mm Prime Lenses
#1 Ariel Glikson
Ariel Glikson
  • 19 posts
Posted 23 October 2006 - 05:10 AM
Hello friends,
I saw this this adaptor:
Angenieux With Carl Zeiss
in http://www.smsprod.c...angenieux4.html
Do you know it? any experience with that? any idea how much does it cost?
Ariel.
#2 John Ealer
John Ealer
  • 187 posts
Posted 27 October 2006 - 07:13 PM
Hello friends,
Ariel.
Pulled from a Zeiss White Paper:
Digital camera manufacturer Sony, striving to gain acceptance for their CineAlta ® High
Definition 24p cameras in the cine industry, contacted cine lens maker Carl Zeiss in
order to find a solution to the lens problems that were observed. This solution would
make it easy for the cine rental houses to add the High Definition 24p cameras to their
existing inventory and simply use their existing and proven high quality cine lenses on
the new cameras, by means of an adapter.
This adapter would couple a cine lens to the High Definition 24p camera, both
mechanically and optically. Optically, it would down convert the image from the cine lens
by a factor of 2.5x to fit it to the size of the 2/3 inch image receiver chips of the digital
camera. This would have to be done with virtually no loss in image quality. The resulting
product, the cine lens adapter CLA 35 HD, created by a collaboration of lens
manufacturers Angenieux and Carl Zeiss, compressed the image from a Zeiss Ultra
Prime lens for 35 mm cine, with a frame diagonal of 30 mm, to the size of the 2/3 inch
imager, with an image diagonal of 11 mm, with virtually no loss. The resulting image
showed 2.5x the resolution of the original cine lens and was 2.5 stops faster. Thus, the
aperture of e.g. T 5.6 on a cine lens would convert into T 2.4 with the CLA 35 HD. The
maximum resolution, output by the CLA 35 HD, would theoretically exceed 500 line pairs
per millimeter (lp/mm). However, the camera?s resolution limit, defined by the imager
chip?s architecture with 1920 x 1080 pixels on an area of 9.6 mm x 5.4 mm and
expressed by its Nyquist-frequency, is 100 lp/mm.
Optically, the CLA 35 HD approach was successful. However, it came with two
drawbacks:
? The CLA 35 HD, inserted between cine lens and camera, added some 200 mm to
the length of the lens and 1.4 kg to the weight.
? Also, being a relay it inverted the image upside down and reversed left and right,
thus requiring an electronic image inversion circuit in the camera.
#3 Ariel Glikson
Ariel Glikson
  • 19 posts
Posted 28 October 2006 - 05:48 AM
Thanks John for this information.
so...I guess the p+s technik pro35 is still the only option to use cine lenses on 2/3 video cameras.
How come there is no competition to the Pro35? How come they are alone in this market?
or is it something I'm missing?
Ariel.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 28 October 2006 - 05:53 AM
Ariel.
There are other players in the market, but it's a tiny market.
Stephen
#5 John Ealer
John Ealer
  • 187 posts
Posted 28 October 2006 - 09:17 AM
Ariel.
Well, though I'd read about the CLA 35 HD adaptor, before your post I'd never seen it in the market anywhere. If it's available, I'm sure it will work and work well. Unlike the Pro35 adaptor, you don't have the light loss issues and you don't have the spinning ground glass (for better or for worse).
J
#6 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 30 October 2006 - 10:34 AM
J
You also have an inverted image and no change in depth of field, which is the reason most people use these adapters in the first place. You also have a very long lens in front of your camera.
This device has been around for awhile, and there's a reason you haven't heard much about it. It functions fine, but its usefulness is limited.
