shooting with Kowa anamorphic!
#1 Rajavel Olhiveeran
Rajavel Olhiveeran
  • 115 posts
  • India
Posted 24 October 2006 - 11:31 AM
hi all
am doing my next feature using the anamorphic lens KOWA. i would prefer to shoot with Hawk series...but my budget wouldnt allow that. kowa apparently is outdated from the international cinema scene. it looks extremely soft to me....but i want to make the best of Kowa. how do i manage to get sharper images.....with better depth of field....and make my images look rich.
do i have to go for more of backligting ......and boosting the actors keylight reading more than the ...available exterior light (day exterior)
i will be shooting on arri 3 with 25mm, 40, 50, 75, 100 mm block lens and HR angenuix zoom.
thanks and cheers!!
#2 Christian Appelt
Christian Appelt
  • 470 posts
Posted 24 October 2006 - 12:08 PM
The Kowa lenses should be a bit softer than state-of-the-art anamorphics, but not that bad!
Is is possible to have them checked/collimated to your camera?
Some ideas about improving image quality:
1. STOP DOWN. NEVER shoot at the largest opening. I suppose the Kowas will look best two f-stops down from wide open. Shoot a few test tables and find out at which aperture the lenses give the best resolution.
2. When shooting outdoors, use ND filters to keep exposure around your optimum f-stop - you will lose sharpness again when you stop down to 11 or 16.
3. In low-level light situations, use faster film stock if necessary to avoid shooting wide open. You have the larger anamorphic frame, so grain should not be a large problem.
Flat lighting and overuse of long lenses will diminish the special look of anamorphic, so I think your idea of using contrasty lighting to get more apparent sharpness is useful.
#3 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 24 October 2006 - 12:39 PM
At least Kowa lenses are as light as spherical lenses, so handheld and steadicam won't be as much of a hassle.
#4 Adam Paul
Adam Paul
  • 304 posts
  • Here and now
Posted 02 January 2007 - 06:05 PM
Is the Kowa in question an anamorphic adapter or an anamorphic lens? I have never heard of Kowa anamorphic lenses, just adapters.
#5 Tony Brown
Tony Brown
  • 689 posts
Posted 02 January 2007 - 06:18 PM
Me neither, I thought they made anamorphics for projectors...... :blink:
I'd try not to fight the lenses, explore the flaws and use them. I love shitty lenses, nothing worse than a pin sharp lens with zero distortion......
e.g for beauty work I'd still use a Mk 1 Cooke 25-250 - rubbish lens by today's standards but great for skin
#6 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 03 January 2007 - 03:51 AM
hi all
I have exprience of use of russian LOMO anamorphic lenses.
I recommend to draw attention on modern russian Elite Optics anamorphic lenses too.
#7 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 03 January 2007 - 03:20 PM
They date back to the 50s and 60s.
They use the older focusing system. But that allows them to be rather compact.
I thought 40mm was the shortest lens availiable.
What is the f/stop and T stop of the 25mm? & the size and weight of it?
Edited by Leo Anthony Vale, 03 January 2007 - 03:22 PM.
