creating a bounce form water light effect
7 replies to this topic
#1 mosh mishali
mosh mishali
  • 13 posts
  • Israel
Posted 27 October 2006 - 02:21 PM
hello
I'm about to shoot a short fantasy film and one secne takes place inside a sewer tunnel, the tunnel will have daylight coming in from small windows between the left wall and the ceiling, on the right wall there will be a long line of dimmed practical lights (100W bulbs), on the floor there will be a water tunnel on one side and sidewalk on the other - i've attached a drowing of the set.
I would like to key the actors with light that is bounced from the water on the actors faces creating an effect of moving lights on them.
what's the best way to do it? i can't put mirrors under the water because it's to expansive and a few kids actors need to step on it, i thought about using an aluminum wrap, but will it bounce enough light?
and how can i keep this scne low lighted and contrasted?
i'll be using an old sony betacam 400 (low budget production) and for lights coming from the outside i will enough baby 1Ks, i hope it will do...
thanks
mosh
#2 Daniel Carruthers
Daniel Carruthers
  • 334 posts
  • Canada
Posted 27 October 2006 - 05:00 PM
hello
thanks
mosh
hi, aluminum wrap works good, just crumple it up then spread it out flat. find somthing you can fill with water like a paint rolling dish, or somthing bigger. spread out the aluminum foil on the dish and pour water over it, then shine a hard light directly on it, and keep it behind the camera, so it evenly fills the frame with water ripples.
it should be real easy to achieve especially for tighter shots, wide shots it might be tricky, so make sure you block out the scene really good.
#3 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 27 October 2006 - 05:08 PM
Hardish light bounced off a length of silver 'disco' fabric hanging and gently agitated by a fan, gives a very realistic light-off-water effect. No water required.
#4 Allyn Laing
Allyn Laing
Posted 28 October 2006 - 12:47 AM
Try bouncing a hard light onto a mirror with a fresh gel placed about 1inch away from the surface and get someone to lightly patter the gel during the shot, depends on how used the gel is for how clean the reflection is, it may work for you it may not goodluck
Allyn
#5 janusz sikora
janusz sikora
  • 82 posts
Posted 28 October 2006 - 07:09 PM
hello
thanks
mosh
The water itself should bounce the light nicely. I once bounced of the pool water surface alone and it looked great.
#6 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 29 October 2006 - 02:24 AM
hi
i just did the same thing on music video that was shoot on a pool i bounce to the water H.M.I par 2.5 and it work real good so bounce light to the water will do the trick its a water of angel and lamp power
if you don't have that kind of lamps try to work with silver hard reflector from outside(if you can) and aim them
to the water or better, use 4*4 mirror
Edited by Ram Shani, 29 October 2006 - 02:25 AM.
#7 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 29 October 2006 - 08:16 AM
Large metal cooking sheets 2"x3" with water in them. You need pans with low sideswork pretty well. Add small pieces of broken glass for more punch from the effect.
#8 Brian Drysdale
  • 5197 posts
Posted 29 October 2006 - 01:23 PM
Bouncing into crumbled silver Mylar works, just gently moving it to create the ripple effect.
