16mm camera with a butterfly shutter
#1 Brian Rose
Brian Rose
  • 896 posts
  • Kansas City area
Posted 03 November 2006 - 05:07 PM
All,
Are there any 16mms out there that have a twin blade "butterfly" shutter? I'm looking for one I can modify with alternating color filters, like Kinemacolor. Thanks
Brian Rose
#2 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 03 November 2006 - 05:11 PM
The K3 and older CP16s do.
#3 David Sweetman
David Sweetman
  • 757 posts
Posted 03 November 2006 - 06:45 PM
As well as the arri 16bl and arri sr1.
of course each 'open' section exposes the same frame...
#4 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 04 November 2006 - 05:52 PM
really ?
I'm a bolex nerd so dont know much about Arri's but what is the reason for exposing each frame twice ?
Talk of shutter angles would become redundant in terms of smoothness as you would always have a segment of motion missing in each frame...
I know that projectors will project and image twice thereby 24fps is actually 48 'flicks' - something to do with that maybe ?
Also wouldn't that make the pull down mechanics have to really heave the film down a lot faster than it really needs to ?
or are you refering to the kinemacolor process ?
cheers :)
Nick
#5 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 04 November 2006 - 06:29 PM
Okay, I am not sure what folks are referring to as butterfly shutters, but if you are really meaning bow-tie shutters, then the Arriflex 16SR does not qualify. The Arriflex 16S, 16S/B, 16St, and 16M all have bow-tie shutters. On the Arriflex, a bow-tie shutter doesn't expose the negative twice, it rotates at half the speed of the movement. The mirror does a complete revolution every two frames.
-Tim
#6 Jonathan Benny
Jonathan Benny
  • 166 posts
  • Vancouver, Canada / Paris, France
Posted 04 November 2006 - 08:43 PM
The disk with two 90 degree openings is turning at half the speed of what a shutter with a 180 degree opening would, therefore the same shutterspeed. Each frame is only exposed once and the film is advanced between each 90 degree opening.
AJB
#7 Sam Wells
Sam Wells
  • 1751 posts
Posted 04 November 2006 - 08:54 PM
Arri S and 16BL segment the mirror itself with a small stripe so you see your "48 flicks" so to speak in the viewfinder but this has no effect on how the film is exposed when the shutter is open.
-Sam
#8 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 06 November 2006 - 11:56 AM
It's only projection which uses the double (or even triple, IIRC, for 8-mm) exposure. If you think about it, you'd get some odd double-exposure effects with a moving subject if cameras did it.
#9 David Sweetman
David Sweetman
  • 757 posts
Posted 06 November 2006 - 02:03 PM
AJB
crazy, so it's 180 equivalent. That makes sense. Sorry for putting out wrong information, I was always told that's how it went down. anyway I'm glad I said it or I never would have known the truth.
I am aware the srII and srIII have variable shutters, but I was fairly sure the srI had a butterfly shutter and was fixed at 180...
