lighting for 16mm
#1 kelly tippett
kelly tippett
  • 64 posts
  • Columbus, Mississippi
Posted 04 November 2006 - 03:28 AM
I'm going to be using 16mm in a feature with a lot more than one location. (hope cam tests go good) I've done some reg 8 years back, and spr 8mm, but this time I'm going to need to understand lighting for 16mm. And I can control the fstops on this film camera- that freedom rocks. Are there any good light meters (inexpensive ones) out there that someone might suggest? And if so where at? Any other tips are very much welcome. If it helps, it Looks to be that I'll be using black and white, 7266. But color is not ruled out at this point plus maybe the next project will be color. The kodak url info on this b&w film is below.
http://www.kodak.com...s...8.8.4&lc=en
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 04 November 2006 - 07:02 PM
The Sekonic Studio Deluxe is a good beginners meter: http://www.sekonic.c...ucts.asp?ID=109
Be sure to check it against a higher end meter before using though, just to make sure it's accurate.
If you got the dough, get the Dual Master, it rocks, and it has a reflective meter as well
#3 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 05 November 2006 - 01:21 PM
HI
SECONIC is a very good exposure meter also minolta and gossen are also good enouph. Why are you shooting reversal film and not negatif? Reversal is good for first timers to learn exposure.
#4 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 06 November 2006 - 02:14 AM
I didn't notice before, but yeah. If you're shooting a feature why are you shooting Reversal film?
Shoot negative, your post-production workflow will thank you for it
#5 kelly tippett
kelly tippett
  • 64 posts
Posted 07 November 2006 - 01:58 AM
I'm going to mini dv and from what i understand negative has more grain. I'll take any advice.
#6 Corey Bringas
Corey Bringas
  • 50 posts
Posted 07 November 2006 - 07:10 AM
so you're shooting a feature lenght film, with little to no understanding of lighting/film itself? I recommend you start by shooting some shorts.. I think there is a misunderstanding and that is probably what you are doing. In that case reversal is great to start with. It is great as a way to first get your hands dirty without having to fork out the money in post processing. BTW- negative does not have more grain. Negative is the standard when it comes to shooting anything of professional quality (unless you're going for the revearsal look of course.) Are you shooting super 16 or just 16? What camera? I typically like to over expose about a stop as I find this more accurately depicts the true rating of the stock. Give us more info about the project! Exteriors, Interiors, day/night?
#7 kelly tippett
kelly tippett
  • 64 posts
Posted 07 November 2006 - 07:05 PM
so you're shooting a feature lenght film... Give us more info about the project! Exteriors, Interiors, day/night?
Plenty of night scenes and interiors. Walking along street passing store fronts. A bar scene. Office shots, int. houses, Halls, apartments, hospital, police station (mock, really just a building with offices). And some day shots- doesn't matter if sunny or cloudy. I want it to look as if it was shot with available light not just clean lighting. Since it is black and white i will not have to worry too much about yellows and blues and white balance. That's not the reason I'm shooting black and white but that is the plus side of b&W. I've shot shorts with super 8, video, and I'm a still photographer. I used to develope my own black and white pics before the digital age became more practical. Now i use the nikon d1 digital. This is the first time using 16mm, very very first feature. I don't have a light meter anymore. I don't really need one now. I know how my still camera lights. Honestly, i don't like a light meter. I know one is needed, but that don't mean i have to like it. So its been a while since i've used one and I'm wondering since it is 16mm do i need to do anyhting different than if i was lighting for 35mm. And honestly any input at all will help.
http://smg.photobuck...gAnch=imgAnch60
<br>35mm still
Edited by kelly tippett, 07 November 2006 - 07:08 PM.
#8 timHealy
timHealy
  • 1262 posts
Posted 07 November 2006 - 07:33 PM
all film has grain, but the effects of it can be used creatively and controlled (reduced or increased) by exposure choices, film stock, and processing.
if you are shooting reversal you should work on understanding how the look of reversal will contribute to the film and story you are capturing compared to shooting on negative. if you lack the experience then shoot some tests and compare.
basically you can reduce grain by shooting on negative film with slower asa ratings and overexposing one half to one full f stop. but always test to see what works best for you.
best
tim
#9 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 07 November 2006 - 08:38 PM
<br>35mm still
Hi
You can use your still camera but its beter to use a lightmeter and specialy a spot meter any way reversal
as i was told is the best way to learn but negatif while you dont have a light meter is best to correct at the
post the exposure mistakes.
Have a nice shooting and enjoy it.
