PL mount? B4 ?
7 replies to this topic
#1 thomas-english
thomas-english
  • 99 posts
  • Steadicam Operator
Posted 06 November 2006 - 08:20 AM
It looks like these bodies are going to ship with PL mounts.
Are s16 lenses good enough to resolve HD ?
Will there be a B4 mount available so I can use digiprimes or a pro35 ?
#2 Brian Drysdale
  • 5194 posts
Posted 06 November 2006 - 04:48 PM
The SI isn't unique in using S16 lenses, both RED and the older Kinetta design plan to use them. However, chances are that older 16mm lenses wouldn't be up to HD.
Being a single sensor camera, you can't use B4 video lenses directly on the SI because they are designed to be be used with the optical block that mounts the 3 CCDs. If you do want to use them you'd need a converter like the Abakus that allows B4 lenses to be used on 16mm film cameras and so they would also work on the SI.
#3 Jason Rodriguez
Jason Rodriguez
  • 175 posts
Posted 08 November 2006 - 10:38 PM
Zeiss Superspeeds and the newer Ultra Primes or Cooke S4-16's (Cooke has some 16mm models out now) are great, and can easily resolve HD resolutions.
#4 Phil Savoie
Phil Savoie
  • 94 posts
  • Montana / Wales
Posted 30 December 2006 - 12:43 AM
[quote name='thomas-english' date='Nov 6 2006, 06:20 AM' post='136671']
I'd say that it depends on the age of the optic and as all lenses are individuals - the individual lens itself. Its been my experience that modern S16 lenses as well as ED Nikons and L series Canon still lenses are up to the job.
#5 Jason Rodriguez
Jason Rodriguez
  • 175 posts
Posted 04 January 2007 - 08:09 AM
Yes, we're seeing the same thing too . . . modern S16 zooms and good primes (like the Superspeeds or the Optars) are definitely resolving enough resolution.
#6 Gary McClurg
Gary McClurg
  • 304 posts
Posted 10 May 2007 - 02:14 PM
So would it be better to go with s16 or 35 lens with the P&S adpater imputed into the camera?
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 10 May 2007 - 02:32 PM
Hi Gary,
Go with the best S16 lenses you can find. I don't think the P+S will resolve anything like 2K
Stephen
#8 Gary McClurg
Gary McClurg
  • 304 posts
Posted 10 May 2007 - 03:36 PM
Hi Gary,
Stephen
Not long after posting... a producer called me and said he was going to order 2 of the cameras and going with s16 lens...
