David Stump's tests
22 replies to this topic
#1 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 13 November 2006 - 06:14 PM
Hi All,
David stump has started posting the results of his tests on CML future cameras list.
Stephen
#2 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 14 November 2006 - 12:14 AM
Can't wait to see the images.
David posted some very meticulus notes on his methods. Right down to what lightmeters he used for which situations, thier serial numbers, when and by whom they were callibrated.
I'm a little disappointed though, he failed to mention what he had for breakfast before he shot the tests.
Very detailed. Very impressive.
#3 Gunleik Groven
Gunleik Groven
  • 117 posts
Posted 14 November 2006 - 03:11 PM
Images
http://www.cinematog...d-exposure.html
Gunleik
#4 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 14 November 2006 - 04:41 PM
EDITED
I wonder if I can say what I think from these grabs, since it looks like anytime someone critiques the RED, on these forums, he gets offended by a team of so-called producers and DOPs who never came here but for promoting this camera... Maybe it's part of a commercial policy to be so agressive I don't know, but, hey, I'll try and prepare for the hard time to come...
- There is no pure black in the image, even though the exposition is low enough so that the whites are not white (at F 19 for instance)...
- The image doesn't look very contrast, in any situation.
- Pity he doesn't go further on the overexposition...
- The colors don't look very saturated, but maybe this is to match the Varicam's color rendering, that is loved by many DOPs, I don't know, but there is a need for color timing after that, just as Varicam needs it, I think.
- Pity there is no definition chart... The Siemens Star is not enough, to me.
Ok, now, RED team, pull the gun... :unsure:
#5 Gunleik Groven
Gunleik Groven
  • 117 posts
Posted 14 November 2006 - 04:59 PM
These are just first posts. There will be more
There are some rather extensive walkthroughs of his procedure over at .net
Gunleik
#6 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 14 November 2006 - 05:03 PM
Sorry you posted while I edited my post... Thanks for the answer, but I wonder what the blacks will look like, at overexposition...
#7 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 14 November 2006 - 05:50 PM
The most interesting part for me was the C-Stand on the left. There is a catch on it that is very telling in how the sensor deals with highlights. Can't say I like it too much, it looks clipped. I love the look of blow-out highlights and obvioulsy that is a problem with digital cameras.
#8 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 14 November 2006 - 06:06 PM
Yes, it blurs a lot, you're right. Even at F 19...
#9 Keith Mottram
Keith Mottram
  • 824 posts
Posted 14 November 2006 - 10:41 PM
The image looks alot softer than a 4k scan, closer to 2k in my opinion. Still for digital it is not half bad. Would love to know if it looks 2k when projected...
#10 Mark Wilson
Mark Wilson
  • 28 posts
Posted 15 November 2006 - 03:59 AM
I'm a bit puzzled.
On the CML site they say: "As usual click on a frame for the full res version, they're 74Mb each!!"
But, a 4K 16 x 9 sensor would have about 9 megapixels. If it had 16-bit analog to digital conversion that would mean a raw data rate of 18 megabytes per frame with no compression at all.
Even if it had separate red green and blue pickups for each of the 4K pixels, (which it doesn't) that would still only a mean a file size of 54 megabytes for 16 bit RGB uncompressed.
So where do they get 74 megabytes from, and what possible use is such a massive file size anyway? (No I don't feel particularly inclined to download the file to find out!)
#11 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 15 November 2006 - 05:36 AM
I dont know as much about digital interfaces for cinematography as I know about computer file formats, but Im guessing that the file is 24bit since that would be 16bit size * 1.5 which would put it at around the size mentioned.
#12 jan von krogh
jan von krogh
  • 454 posts
Posted 15 November 2006 - 06:47 AM
I'm a bit puzzled.
The sensor is 12 Megapixel - not 9. 30% higher than you assume.
resolution is 4900x2580. on S35 AR it will be ~4520x2540, a bit higher than 4K.
it has 12 millions readout pixels - which are converted to RGB. add the 30% higher resolution compared to your assumed 9MP and there you go.
Also it is not only 16 uncompressed to store, some dozens bytes to add, which go into the LUT :)
a) the oversampling of the sensor makes sense in order to compensate the given resolution reduction when debayering a CMOS-basing photographed image.
B) the files are not huge. that is 4k biz as usual - pretty common in top-end cinematography since some years. i know most of 35mm and digital releases are done 2k today, however: even if you dont use 4K for your release, but go for a typical theatrical 2K release, it gives you many important advantages aquiring and postproducing in 4k. Here a some.
- pan & scan: with 1080p & 2K, be it 35mm or cinealta or whatever, you dont want to enlarge or pan your image.
- noise : you can push the borders in DI & colortiming/grading quite a bit further in 4k - when noise begin to show up slightly in 4k, your downrezzed 2K will not show it, or at least much weaker.
- postproduction & VFX: for pulling keys, tracking/stabilizing etc the higher resolution is a blessing. Also, VFX assistants can be a little bit less tight when masking, rotoscoping etc.
- sidenotes: print: yes, i know this might sound bizarre, but certain dops will use RED as digital still SLR camera as well, and 4K is useful for printing larger sizes.
furthermore, with the optional redcode wavelet datareduction, you only need ~30MBytes/sec for 4k datareduced, and the higher resolution makes the datareduction, if one wants to use it, quite useable for cinematic release. however, we will have to push the footage through the DI workflow first in order to understand how much the datareduction will reduce colorgrading etc.
On cinealta we typically shoot a mix - uncompressed 10bit to disk for rather comples postprodution shots, to tape for "usual" shots.
24bit is = 8bit/channel*3, the images from david stump are 16bit/channel + lut. the final will "only" be 12, not 16 bit. the 16bit a there as REDCODE isn´t available yet, and 16bit tif is common.
also, the images are not only 4K, but 2540+. 4900x2540 from the red frankie protoype. 4540x2540 will be the 4K in S35 from the serial red one.
the images are coming from the uncharacterized sensor, no sharpening at all, no colorcompensation etc. also the charts contain syncing problems the sensor was misaligned often etc. red however is ok with having the prototype shots published.
#13 Keith Mottram
Keith Mottram
  • 824 posts
Posted 15 November 2006 - 07:06 AM
no it doesn't sound bizarre. it sounds like a load of old bollocks.
#14 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 15 November 2006 - 12:20 PM
A very heavy & expensive SLR IMHO.
Stephen
#15 Keith Mottram
Keith Mottram
  • 824 posts
Posted 15 November 2006 - 12:37 PM
Would be very useful for those photographers who find an optical viewfinder a burden though....
#16 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 15 November 2006 - 01:48 PM
4900px * 2580px = 12642000px
12642000px * 16bits = 202272000 bits
202272000 bits * 3 channels = 606816000 bits
606816000 bits = 72.3381042 megabytes
- Gavin
#17 jan von krogh
jan von krogh
  • 454 posts
Posted 15 November 2006 - 02:23 PM
Stephen
even if we certainly won´t replace our making-of Canon 5D by the red - i overheard several talks of RED-buyers, especially indy-dops, who intend to do so at IBC 2006.
1) to buy 2 cams is more expensive
2) to carry 2 cams is heavier than one - and the 3.1 kg red has to be brought on set anyhow.
also, taking stills through cookes, zeiss, angenieux isn´t to bad either.
#18 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 15 November 2006 - 02:29 PM
Just thought I would mention: Overexposure stops are now available on the color charts on CML. And it looks like Green Screen material is imminent.
#19 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 15 November 2006 - 08:41 PM
Can you give us a new link, then, browsing CML is a pain in the neck. Thanks !
#20 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 15 November 2006 - 11:15 PM
Exactly the same link as before just more of them:
(They're under "Comparative Tests" on the main page.)
Edited by Gavin Greenwalt, 15 November 2006 - 11:17 PM.
