What happens when you use telephoto primes with super 16mm?
#1 Zachary Vex
Zachary Vex
  • 208 posts
Posted 15 November 2006 - 05:26 AM
I have an old prime that I got with a Bolex, and I'm going to stick it on a Kodak K100 this weekend while in Vegas in a helicopter... the camera is modified for super 16.
Will the lens cover super 16mm? Cooke Telekinic 3" f/4 Anastigmat Taylor/Hobson England is what it says.
Anybody?
#2 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 15 November 2006 - 06:33 AM
I am not sure if it covers S16, but I do know that if it has not been re-centered for S16, the lens will not track properly as you change focal lengths.
#3 timHealy
timHealy
  • 1262 posts
Posted 15 November 2006 - 08:55 AM
Kevin, I assume you mean if the camera hasn't been recentered... I have never heard of a lens being recentered unless there is some process I am not aware of.
I guess the issue of tracking though would not be an issue since it is a prime lens.
Zach... Anyway to test the camera before you go and shoot with it if you have doubts?
best
Tim
#4 Ian Marks
Ian Marks
Posted 15 November 2006 - 09:05 AM
Generally, longer focal lengths project a larger image circle, so you're probably okay on coverage. Three inches is about 75mm, a moderately long focal length lens for 16mm. Of course, if the lens is designed for standard 16, its best performance may not extend to the extreme corners of the Super 16 frame.
Regarding what Kevin said, I think he misspoke, as you can't change focal lengths on the lens you describe - it has a fixed focal length. In any event it's the lens mount that should be re-centered (by 1mm, I think) on a camera modified for Super 16. If your lens mount hasn't been recentered, you'll just have to try your lens to see if the coverage is adequate (if it isn't, you'll see a problem in the corners of one side of the frame).
You can avoid problems by using a lens designed for 35mm still photography, which will provide such a large image circle that the off-center lens won't be an issue. You can mount this to your K100 using C-mount adapter. However, the larger lens will probably interfere with the K100's finder objectives. Hope this helps.
