DIY COLOR CORRECTION
7 replies to this topic
#1 Kenny N Suleimanagich
  • 902 posts
Posted 15 November 2006 - 11:41 PM
CRAZY process, I read about someone who color corrected a 10 minute short (16mm -> DV) on a Mac Pro correcting FRAME BY FRAME in Apple Aperture (PHOTOGRAPHY color correcting software). Such a crazy process, but it looked damn good for the effort.
Anyone ever heard of something like that?
#2 Michael Collier
Michael Collier
  • 1262 posts
Posted 16 November 2006 - 05:10 AM
Not personally (I have though in my younger days before I discovered after effects) created traveling paintings by exporting frame by frame and then painting in photoshop and then re-importing into premiere. I imagine if you want to color correct that way there are things you can do to semi-automate the proccess (in premiere you can export in Tiff frames, then in photoshop you can create macros and tell it to apply the same macro to each frame, then in premiere set the standard still length to one frame. saves repetative work I suppose, and I am sure there are similar functions on the programs they used)
Possible....but why? There are so many better ways to go about it (even on low budget)
#3 Joshua Provost
Joshua Provost
  • 71 posts
Posted 16 November 2006 - 03:42 PM
Is there some advantage to correcting frame-by-frame instead of shot-by-shot like most people do? I can't think of any advantage to it, just lots more work.
#4 Josh Bass
Josh Bass
  • 552 posts
Posted 16 November 2006 - 04:08 PM
Perhaps the tools in photoshop are have finer controls than those in, say, Premiere, Vegas, Final Cut Pro?
#5 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 16 November 2006 - 05:02 PM
No there isn't.
Because if you don't apply the same correction to each consecutive frame the image will be jittery, flickery and unuseable. So what you're doing is probably correcting one frame and then executing a macro on the rest of the shot. Which isn't actually correcting frame by frame.
If you want a changing color correction then you'll want to animate the effect anyway so that it's smooth.
I have hand rotoed mattes in Photoshop and Cinepaint frame by frame before, and that's also an exercise in precision so that your matte doesn't flicker, but it can be done, and is probably the only thing I would do frame by frame.
Edited by Gavin Greenwalt, 16 November 2006 - 05:03 PM.
#6 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 16 November 2006 - 05:09 PM
http://digitalconten...neman_pipeline/
Somebody posted about this a couple days ago. Sounds like a lot of tedious work if he's describing it accurately, which I suspect he's not. It's probably more like what Gavin said.
#7 Matthew Buick
Matthew Buick
  • 2345 posts
  • Newcastle upon Tyne, UK.
Posted 16 November 2006 - 05:26 PM
Would it be possible to shoot Monochrome Super 8 and colour correct to get realistic vivid colours?
#8 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 16 November 2006 - 06:35 PM
Yes. But there are a lot of tricks to coloring large amounts of footage that don't involve having to hand paint each frame. Any time you start talking about hand manipulating footage, it'll amost always be easier, quicker and higher quality to use roto-shapes, keying and animated strokes. The exception are extremely fine internal details which sometimes take longer to roto than just hand paint.
It all goes back to how much time you want to spend, and how good you are. I've always said that you can do anything in any software package.
3D Studio Max and Maya are nothing more than fancy text editors. You could do everything they do inside of notepad. But the effort, time and quality would suffer. This is a case where apparently the user decided to attain quality at the expense of time. But that doesn't mean it was the best approach, you could have created the same results in much less time using: Fusion, Shake, Nuke, Combustion or After Effects. It's much like telecine: yes you *could* run all of your 35mm frames through a slide scanner, but it's by no means the best approach.
- Gavin
