Time Code In Monitor
#1 Scott Imler
Scott Imler
  • 46 posts
Posted 17 November 2006 - 10:59 AM
Hi guys I know in order to see characters such as Time Code in the monitor you have to have the "Character Out" switch on. I have done that but still do not see time code in monitor. I have tried both outs . Is there an item buried in the menu somewhere that I am missing?
Edited by Scott Imler, 17 November 2006 - 10:59 AM.
#2 Scott Imler
Scott Imler
  • 46 posts
Posted 17 November 2006 - 11:16 AM
Found the mystery menu setting no need to reply Thanks
#3 Gabriel McArtney
Gabriel McArtney
  • 7 posts
Posted 03 February 2007 - 10:41 PM
Hi
I'm currently camera assisting on a VariCam feature and I have had the same problem.
Could you please explain how you did it? I too have tried all the TC settings in the menu and both HD SDI Outs but nothing seems to work.
Thanks in advance
Gabriel
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 05 February 2007 - 03:07 PM
Go to the VTR Main menu.
Select the Function menu.
Select the Character Out on SDI menu.
Switch to Status (instead of Menu).
Now everything (except framelines) that appears in the viewfinder will appear on the monitor.
#5 Phil Rhodes
  • 12167 posts
Posted 05 February 2007 - 03:31 PM
Is there any way to turn the "Low Light" warning off in the viewfinder?
Phil
#6 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 06 February 2007 - 03:26 PM
Yes, it's in the viewfinder menu. You can adjust the exposure level at which it will come on. We typically have it set at 35 IRE but you can dial it down to OFF.
