Stranger Than Fiction
#1 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 17 November 2006 - 11:56 PM
Holy Cow! Was it just the print I was watching or all of them? It looks like someone at the print lab left out the matts or the final render didn't have the matt filter engaged. Either way, someone is getting a royal ace chewing about now. I assume that as it seems impossible to me that they would release the movie with the boom mikes showing.
#2 Mike Panczenko
Mike Panczenko
  • 324 posts
  • 2nd Assistant Camera
  • Philadelphia, USA
Posted 18 November 2006 - 12:09 AM
The projector probably wasn't framed up properly. Oftentimes, the movie will be filmed with the boom outside of the intended projection part of the frame (the negative is 1.37:1, so you have significant headroom with a 1.85 movie). This assumes, however, that the print will be framed up correctly in the theater, since the boom is still recorded onto the negative. Most of the time when you see this is theaters, it's projectionist error.
#3 David Mullen ASC
Posted 18 November 2006 - 01:20 AM
Most 35mm 1.85 movies are shot "open matted" and contact-printed -- so it's up to the projectionist to properly frame the image on the print, which has no hard mattes. The projector has a 1.85 mask in the gate, but the image can be shifted up or down. Usually when boom mics are visible constantly, it's because the projectionist has too much headroom (the frame is shifted down too much.)
If you notice this, you should tell the manager that the image needs to be raised.
