Kino Ballasts
#1 Cody Jacobs
Cody Jacobs
  • 9 posts
  • Chicago, IL
Posted 21 November 2006 - 12:02 AM
If the hertz rate is not consistent will you get flicker from a kino or does the ballast regulate the voltage to the head?
#2 Frank Barrera
Frank Barrera
  • 473 posts
Posted 21 November 2006 - 03:37 PM
The Kino Flo ballast is designed to regulate the voltage that it sends to the tubes. It has no effect on the Hz. It will not operate properly if the Hz is fluctuating more than normal. The same goes for HMI ballasts.
f
