Thinking of trying Eterna 250T on std 16
11 replies to this topic
#1 Matt Irwin
Matt Irwin
  • 389 posts
Posted 22 November 2006 - 05:14 AM
Just curious how 8653 is on standard 16 with regards to grain and contrast-- Never used Fuji stocks before and I'm thinking of trying it on a project coming up.
Tape finish on Pro50 or digibeta, going for a 50% desat/hi-con look.
#2 Chris Burke
Chris Burke
  • 1723 posts
  • Boston, MA
Posted 22 November 2006 - 07:53 AM
I am just doing my DI on a short that we shot with the 8653 on super 16. I was very pleased with the results. I imagine that if you had a great camera with an even better lens and the transfer was top notch, you would get stellar results. Here is an example of what we shot, it is a one light for edited, but I have seen some of my footage onlined and it was incredible. www.chrisburke.net then click on the link labled "Gates clips 2".
#3 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 22 November 2006 - 08:36 AM
I have done a project the summer using eterna 250 t s 16 and the film was very good. In interiors ihad used
4 dedos and an arri soft the contras was very good and the colors were perfect. I a scene using fluoresent lights warm white was desaturated alot. Not grain at all. Even after the blow up to 35.
#4 Matt Irwin
Matt Irwin
  • 389 posts
Posted 22 November 2006 - 02:25 PM
Sounds good, thanks guys.
How would you compare it to 7217?
#5 Rick Sharf
Rick Sharf
  • 15 posts
Posted 27 May 2007 - 12:42 PM
ya im also curious to how you think this would compare to 7217. Im trying to decide which stock to go with, so some more info would be great!
thanks,
Rick
#6 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 29 May 2007 - 02:38 AM
Chris, I went to your website but I couldn't find any link labelled "Gates clips 2". I did click on 'Gates' though that led to a series of production stills.
#7 Mike Williamson
Mike Williamson
  • 534 posts
Posted 29 May 2007 - 03:53 AM
Last summer I shot a Super 16 feature where we used Fuji stocks, I opted for the Eterna 500T (about 90% of the film) and the F-64D. The reason I used 500T was that according to the spec sheets, it has the same RMS granularity as both 250 speed stocks, so I figured there wasn't much point to carrying more stocks if there wasn't a grain advantage. I also rated the stock at 320 which probably helped.
I did not shoot tests comparing the 250 stocks, so who knows, but I was very happy with the look of the Eterna 500T for whatever that's worth. It matched very well with the day exteriors on 64D, no big differences in grain that I noticed, in SD dailies telecine anyways...
#8 Matt Irwin
Matt Irwin
  • 389 posts
Posted 29 May 2007 - 08:37 AM
Rick,
I just shot another short project on 8653 Super16 using older Zeiss MK1 primes, TK'd on a Spirit 2k. The results were better than I had hoped for. I haven't shot 7217 on a project but I have tested it, and I'd say that 53 is a bit less grainy and contrast is very close. It stands up surprisingly well to high contrast lighting (I was around 5:1 or 6:1). Very smooth stock.
Hope that helps.
#9 David Mullen ASC
Posted 29 May 2007 - 08:55 AM
Eterna 500T has the granularity of the old 250 stocks ('52 & '62), not the new Eterna 250 stocks ('53 & '63).
#10 Mike Williamson
Mike Williamson
  • 534 posts
Posted 29 May 2007 - 05:01 PM
Not according to the Fuji spec sheets, which list '53, '63 and '73 as ALL having an RMS granularity of 3.5. As I said, I haven't tested them myself and it might be that this doesn't really reflect what you see on the screen, but that's what they state in the brochures that I've got.
#11 Chris Burke
Chris Burke
  • 1723 posts
  • Boston, MA
Posted 31 May 2007 - 06:47 PM
check the link that says "preview"
chris
#12 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 06 June 2007 - 03:22 AM
Nice work Chris. The footage is very natural looking and I liked soft light. Nice and sharp too. Ive just got a 16mm work print back made from a roll of Fuji Eterna 250D negative I exposed a little while ago. Viewing several frames with a loupe, the images looked fairly clean and fine grained to my eyes.
