Green Screen for Wide Shot of Multiple Subjects
#1 Taina Galis
Taina Galis
  • 5 posts
Posted 22 November 2006 - 09:33 AM
Hello
I would value your advice about how to light a green screen shot on HD where the floor and wall are visible. The subject is 7 actors seen from head to toe, all walking in circles.
I am particularly looking for advice about how to keep the actors' feet separated from the floor.
Also, how far away from the screen should the subjects be at a minimum? Their bodies must be fully visible and they are moving quite close to each other.
As the subject area is large, I'm expecting it to be very tricky to separate them fully from the background. I thought to light them predominantly from the sides. Any other ideas?
Thank you.
Taina
#2 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 22 November 2006 - 04:27 PM
Try to softlight the whole area as much as possible, from all sides and top. The idea is to get a basic soft, shadowless "fill" over the whole area to light the screen and floor so that the actors' shadows are as light and soft as possible. Depending on the space, try hanging a couple large frames of silk to push light through or bounce material to bounce light from above.
Then, you can light your subjects more strategically from side angles (that is, the lights not too high up), taking care to flag this light off the floor and back wall. Be prepared to have lots of flags and stands to "box" your lights in to contain the spill. The actor's feet and ankles will naturally go a little dark, but if the light is cut softly it doesn't have to look objectionable.
As for the distance from the back wall, give yourself as much room as possible for lighting. The farther away the wall is from your subject, the more frontal you can get with your lighting without it throwing shadows on the background.
Don't worry about green spill on your actors. You generally want to underexpose a green screen a little bit anyway, so the green ambience shouldn't be a problem unless there is a lot of white wardrobe.
#3 Taina Galis
Taina Galis
  • 5 posts
Posted 24 November 2006 - 05:35 AM
Thanks Michael. That's really helpful.
#4 jed read
jed read
  • 14 posts
  • taree, Australia
Posted 25 November 2006 - 03:40 PM
for the wall try licra because it doesent wrinkle and there will be a faint line were the wall and floor meets.get some light lime green sheets (note the licra has to be light lime green as well) and tape the sheet to the licra and put it along the floor.make the sheet curve were it meets the floor and wall,so there is no line. B)
#5 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 26 November 2006 - 05:27 AM
I too have a greenscreen project comin' up. I've never done it with 16mm, which is what I'll be doing.
My only question is, will there be any problem if I add a kicker to backlight my subject?
#6 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 26 November 2006 - 09:16 AM
i'd say no, unless it's a green kicker.
#7 Taina Galis
Taina Galis
  • 5 posts
Posted 04 December 2006 - 11:03 AM
A back light helps separate subject from green screen. If acceptable to your colour scheme, it also helps if you use a gel of opposite colour- magenta for greenscreen, or orange/yellow for bluecreen.
