exposing an explosion
#1 cdncam
cdncam
  • 2 posts
Posted 23 November 2006 - 03:25 PM
looking for advice on which is the best way to judge exposure for an explosion. the explosion is happening at night against a black sky. it is only tht flame element that we are shooting at this point and im wondering what the best way to take a reading is, as there will be test explosions allowing me to meter. thanks in advance for any help and advice
#2 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 23 November 2006 - 04:11 PM
I assume it?s a fireball you are talking about exposing.
If so, typically at 400 iso you should be at a 5.6/ 8 split and you should be fine.
#3 marc laliberte else
marc laliberte else
  • 8 posts
Posted 23 November 2006 - 10:30 PM
I find that if you ar eexposing for the fireball itself with nothing in th e FG or BG worth keeping at exposure then a deeper stop gives more detail/chrominance to the flame. the brightest part of the explosion is v. quick though so if you are not shooting 150fps or higher then the 5.6-8 rule works as it keeps most detail in the burnout.
mle
#4 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 23 November 2006 - 11:02 PM
I should have added the 5.8/ 8 at 24 fps, but you typically would be overcranking.
