Nizo s800 - Using with an external light meter
#1 grantsmith
grantsmith
  • 138 posts
  • 2nd Assistant Camera
Posted 23 November 2006 - 05:11 PM
Hi there,
I've just got hold of a s800. I'm wanting to use it with an incident light meter but I'm not exactly sure how to measure it.
It didnt come with the instruction manual so I'm not exactly sure what shutter size to meter it for. And also, I heard that the reflex design takes a little bit of light away so I would have to compensate anyway.
If anyone knows what to set my lightmeter up as to get the best exposure possible with the s800 that would be really appreciated.
Also, Is there any (except for the fps difference) picture quality difference between the s800, 801 and professional? I'm assuming not as they have the same lens.
Cheers,
#2 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Zürich, Switzerland
Posted 24 November 2006 - 09:16 AM
http://super8wiki.co..._P_Professional
http://super8wiki.co...ex.php/Nizo_801
http://super8wiki.co.../Nizo_801_Macro
unfortunately it doesn't tell the shutter-angle, I guess 180... I'd start tests with 1/3 stop compensation for prism light-loss...
#3 jeff heit
jeff heit
  • 2 posts
  • Big Bear Lake, CA
Posted 24 November 2006 - 04:29 PM
shutter = 170
so 1/50th at 24fps
#4 grantsmith
grantsmith
  • 138 posts
Posted 24 November 2006 - 05:36 PM
Thanks Jeff,
Do you know how much I will have to compensate for with the reflex prism?
Can I get away with using 1/30 for 18fps (my meter only does 1/50 or 1/30) or will I have to compensate with exposure if shooting reversal?
#5 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 24 November 2006 - 11:38 PM
An extra half stop open usually does it with the Nizo's
Edited by Anthony Schilling, 24 November 2006 - 11:39 PM.
#6 Bernhard Zitz
Bernhard Zitz
  • 342 posts
Posted 25 November 2006 - 11:29 AM
18fps with 170 shutter-angle would be 1/38...
If you can do 1/60 on your meter I'd go for this, this gives a little more than a 1/3 stop compensation...so you should be fine...
do you mean using a reversalstock? Normaly you expose it as usual, be aware that it hasn't the latitude of a neg. I prefer to underexpose slightly colorreversal, it looks more saturated, but that's just my taste...and bright hightlights can go very bright on colorreversal...
#7 Bernhard Zitz
Bernhard Zitz
  • 342 posts
Posted 25 November 2006 - 06:25 PM
sorry my calculation went wrong :D , better to use 1/50, that makes a little less than 1/3 stop compensation
