HMI Camera Light?
#1 Mike Nelson
Mike Nelson
  • 7 posts
Posted 29 November 2006 - 04:17 AM
Hi.
I want to buy an HMI light that I can use in the field off battery power (on camera would be great).
It must be reasonably small and light. I'd like to use it for a key light (overcast days) and a good grunty fill (Sunny days).
I don't mind spending more to get the best light for the job.
Does anyone have any recommendations?
I've never used them before.
Thanks.
Mike.
#2 roy farag
roy farag
  • 14 posts
Posted 29 November 2006 - 09:53 AM
Hi.
Thanks.
Mike.
hi mike
if you are looking for some kind of a "minilite" which mounted on the comera' small and portable' check out a "mini ark" its a small day light minilighat which is pretty good for your aims'. i you are looking for somthing softer you can try 2 kinos mini flow which can be attached to yourcamera ( great for closeups)and they come in a varity of light temp.
roy
#3 David Mullen ASC
  • 20072 posts
Posted 29 November 2006 - 11:24 AM
Small HMI's
http://www.arri.com/entry/products.htm
http://www.frezzi.co...mi_lighting.htm
http://www.k5600.com...ucts/index.html
Daylight LED's
http://dvcreators.net/litepanels
#4 Mike Nelson
Mike Nelson
  • 7 posts
Posted 30 November 2006 - 04:23 AM
Thanks for the info.
Almost all of the lights you've suggested could be of use. They all have their pros and cons.
It's going to be hard making a decision.
Thanks for your time.
Mike.
