Using print film in camera
17 replies to this topic
#1 james smyth
james smyth
  • 48 posts
Posted 05 December 2006 - 04:16 PM
I'm looking to use Kodak EXR 7386 in a camera to save costs on film stock. This is for a student project, so problems with color balance etc are okay to a certain extent. I was wondering if anyone would happen to know about what ASA/ISO this would be rated at? My professor says most color print stocks have an ASA around 12 or 16, but I can't find any resources that really say.
#2 Kenny N Suleimanagich
  • 902 posts
Posted 05 December 2006 - 06:33 PM
yeah, they are a very nonsensitive emulsion becuase when you're printing to use a light bulb that projects one to the other. Moreover, print film i believe would be equivalent to a reversal stock because it makes a positive.
Hope that helps.
#3 james smyth
james smyth
  • 48 posts
Posted 05 December 2006 - 07:09 PM
Hmm, I always assumed prints were made from negative originals.
#4 Kenny N Suleimanagich
  • 902 posts
Posted 05 December 2006 - 08:14 PM
well they are, execept it's to produce a positive not another negative.
#5 Chris Keth
Posted 05 December 2006 - 08:32 PM
Print stocks are negative stocks. You're making a negative of your original camera negative, which yields a positive.
The 12-16 EI is stretching it. I tested it once and got something more in the realm of 3-6. Unless you want to undercrank everything and shoot only outdoors in full sun, you probably won't have the stop for it. I'd stick with regular negative film, or if you need a print and want to be thrifty, reversal stocks.
#6 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 05 December 2006 - 09:00 PM
Shoot a positive with a negative acting stock you get a negative, copy that on a negative acting stock and you get a positive..
BUT BUT
POsitive stock is contact printed a few inches from a 300+ watt bulb.. (I think I read somewhere thet the B&H printer used a DDB 750 watt bulb... So it will be VERY SLOW. Think T 1.4 in daylight.
The positive stock does not have the prity orange mask which means that it will not print well, as the mask literaly masks some sortcomings in the available colour dyes.
Print stock has positive pitch, so it may not run happly in the camera, and printing with it may be unstaedy.
The lab may have to stick a blank piece of Colour negative film, cut from a developed blank roll of 120 in the gel holder on the printer to get the light somwhere close to correct to make aprint.
POsitive stock os almost always Polyester, which will be a pain to edit. (unless you are scanning and editing as video)
By all means it is an interesting experiment, but .......
#7 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 06 December 2006 - 03:44 AM
I know your question is about color print stock but, if you were shooting B&W you could push process to get back some of the speed. However this would increase the contrast and grain, which might be acceptable for artistic reasons :ph34r: Also some of the B&W printing stock is sensitive to the blue light only so the sky would render as the lightest value. Combined with hand cranking you might end up wit that real old time early cinematography look.... :blink: "The Battleship Potyomkin" perhaps?
"All claims subject to testing and verification. Not responsible damage to equipment, personal injury, death, or acts of God" :D
#8 Zachary Vex
Zachary Vex
  • 208 posts
Posted 06 December 2006 - 04:24 AM
If your object is to get something that can be projected straight out of the camera after processing, just use reversal. That's what it's made for! It's beautiful stock that produces fantastic contrast... just make sure you expose it properly. Not much latitude to fool around with!
#9 Delorme Jean-Marie
Delorme Jean-Marie
  • 513 posts
  • paris, france
Posted 06 December 2006 - 04:56 AM
load the camera properly because if it jams, the motor will smoke way before the film brakes.
#10 james smyth
james smyth
  • 48 posts
Posted 06 December 2006 - 08:56 AM
Why B&W? Are you not able to push color?
#11 Clive Tobin
Clive Tobin
  • 402 posts
  • Spokane Valley, WA, USA
Posted 07 December 2006 - 08:50 PM
...POsitive stock is contact printed a few inches from a 300+ watt bulb.. (I think I read somewhere thet the B&H printer used a DDB 750 watt bulb... So it will be VERY SLOW. ...
The old B&H J and D printers used a weird CWY 300 watt lamp, the newer C and Panel printers used a CTS/CTT 1000 watt or CYS 1200 watt, or a 1200 watt newer halogen replacement. However these latter printers were very inefficient for light output because of the complex system of dichroic mirrors and the need to have the light bulb filament totally out of focus to prevent exposure nonuniformity, and were run at reduced voltage to make the lamps more stable and long-lived. And this is for printing at anywhere up to 960 feet per minute so the exposure time is short. So the print stock isn't quite as deadly slow as you might think, though it is in the single digits.
One approach I was playing with for a while was exposing color positive print stock in a camera through a very strong yellow filter such as a #12. This exposed only the red and green sensitive (cyan and magenta forming) layers. After normal color positive type processing you can print it on B&W positive stock and get nearly normal contrast. This is because the B&W stock is only blue sensitive, so it is only seeing what is normally the unwanted impurities in the color dyes, so the contrast (gamma) is in effect reduced to a small percentage of normal. So a gamma=4 stock approaches a gamma=.6 or more or less normal B&W negative contrast. It is still very slow though and the scale is short.
#12 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 07 December 2006 - 11:22 PM
Are print stocks B wind or A wind? I know from common knowledge that films designed to be run through cameras are B wind.
#13 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 08 December 2006 - 01:45 PM
Reversal print stocks would have been in that range.
Makes me suspect that your professor's experience on the subject is reading a very old Lenny Lipton book.
7361 B/W reversal was around EI16 and gave a beautiful image.
I've also shot an Anscochrome print stock that was EI25.
Ektachrome print was supposedly EI12.
The color print films would have been similar to ECO.
But that's all in the past.
#14 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 08 December 2006 - 01:59 PM
Hand cranking did not give inconsistant exposures as it does with the contemporary travesty of it.
In 'Alexander Nevskii', Tisse handcranked shots of people wielding prop weapons where overcranked the upswing and under cranked the down swing, while changing the shutter to keep the exposure consistant.
That sugestion is an insult to a generation of cameramen.
Also B/W print film is normally processed in a positive developer, thus yielding a high gamma.
Forcing the development would yield a contrastier image, eliminating middle tone.
It can de developed in a negative bath which will yield a gamma in the normal negative range, but with an EI of around 1.5.
Quick: how are fleshtones reproduced on a blue sensitive stock?
#15 Clive Tobin
Clive Tobin
  • 402 posts
Posted 08 December 2006 - 07:11 PM
Most print stock if single perf is A Wind. Although users of Panel printers used to buy equal quantities of both A and B Wind in order to make prints in both forward and reverse, for about double the productivity. The prints made in the opposite direction would be rewound before processing, in order to get the sound track in the right place to accept sound track redeveloper application for a silver plus dye track.
The wind can be changed by rewinding the roll before exposure, of course. You need to be careful doing this if using 3000 to 6000 foot rolls.
#16 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 08 December 2006 - 08:49 PM
My apologies for the unintended insult. Let me assure you that I have nothing but respect for the pioneers of cinematography. However I was referring not so much to changes in exposure but rather the apparent under cranking that "sometimes" resulted from the fatiguing of the camera operators arm on longer takes.
The flickering of the image seen in "some" films may have been due to any number of things, including the age and condition of the print. I am sure that results back in the day varied for the same reasons they do today; technical and artistic competence. Never the less I'd like to think that consistent exposer over time is easier to obtain with a good motor, as opposed to keeping time by humming your favorite tune.
Yes it would, and Iwrote: "However this would increase the contrast and grain, which might be acceptable for artistic reasons"
In the beginning... there was blue sensitive stock.... shortly there after came make artists with green lipstick.
You can push color, though probably not as far, but then you have to pay the lab extra money to do it. B&W you can push in at home using your own chemistry.
#17 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 09 December 2006 - 02:44 PM
I think that was more of a deliberate style than an accident.
If you come across ancient manuals, you'll find they sometimes recommend cranking the projector faster than the camera.
Clown white make up.
Continental Europe seemed to prefer the darker faces.
#18 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 10 December 2006 - 07:07 PM
I'd love to get a look some those old tomes. I used to haunt the stacks of the library at m old university in Hawaii, but the earliest material I could find was from the thirties. It's funny because even in those books they referred to earlier cinematic techniques as being obsolete :o
http://www.ntm.cz/da...inematograf.jpg
I'm working on a project now where I need to reference early techniques as they are integral to the story. I'm talking about duplicating some of the early work by Muybridge and Edison.
http://images.google...g...es&ct=title
