Digital latitude tests
31 replies to this topic
#1 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 December 2006 - 09:15 AM
This may be of interest to some peole here.
http://www.cinematog...ts/HDcurves.htm
Stephen
#2 Keith Mottram
Keith Mottram
  • 824 posts
Posted 11 December 2006 - 09:36 AM
Stephen
i'm not very good at reading graphs- does the D20 have the largest range or am i mistaken? i am somewhat confused, can you give me a breakdown Stephen?
cheers,
keith
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 December 2006 - 09:53 AM
cheers,
keith
Hi Keith,
D20 would seem to be a clear winner.
JJ did post on CML that they had made vast improvements since David Stumps tests. Time will tell.
Stephen
#4 Francesco Bonomo
Francesco Bonomo
  • 366 posts
  • currently in Rome, Italy
Posted 11 December 2006 - 11:03 AM
So it seems, I wish I could run a few test with it (and the Viper, too), but there's still no D20 in Italy yet. Of course, Latitutde is not the only thing we should look for in a HD camera, but this chart is very interesting indeed. I'm not surprised by the F900 curve, but it's curious to see a new camera, Red, so close to the F900 latitude (at least in the straight line region).
Isn't it a little bit ironic seeing the D20, a camera advertised as being targeted at the TV market, having the best latitude? :D
Thanks for posting this, Stephen
#5 Brian Drysdale
  • 5198 posts
Posted 11 December 2006 - 11:06 AM
Hi Keith,
Stephen
The Canon held up surprisingly well.
#6 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 December 2006 - 12:58 PM
Hi Francesco,
I've been shooting with the Viper as it's the best I have available in Switzerland.
Arri are realistic that the D20 should be targeted at TV, it's still no where near the latitude or Dynmic range of film. Having a horse in both races keep's their feet firmly on the ground.
Just my 2c
Stephen
#7 Francesco Bonomo
Francesco Bonomo
  • 366 posts
Posted 11 December 2006 - 01:16 PM
Stephen, I didn't mean to compare film's latitude to the D20 (I'd never dare to say something like that, yet!). What I meant is that a camera supposedly aimed at the tv market shows to have a better latitude curve than cameras that have been marketed as good replacement for film.
#8 George Lekovic
George Lekovic
  • 69 posts
Posted 11 December 2006 - 01:54 PM
Interestingly,
RED seems to have flunked this test, as curves show mere 7-8 stops of latitude. Or am I misreading the chart?
George.
#9 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 December 2006 - 02:17 PM
Interestingly,
George.
Hi George,
Funny thing was, I said I was dissapointed with the images I saw at IBC and got flamed. I wanted to test the camera myself but was refused!
BTW Jim, I don't think there is anything wrong with your sensor
Stephen
#10 Graeme Nattress
Graeme Nattress
  • 145 posts
Posted 11 December 2006 - 04:40 PM
Well, you've got 6 cameras, tested at 6 different times, with different procedures. That chart is about as useful as a chocolate teapot. Not least it's comparing finished, in the field cameras, when RED is still in heavy R&D and does not yet exist as a fully finished camera. Indeed, the tests that David did with us did allow us to change some sensor variables and for us to achieve better results. Without a proper test methodology, such tests, when combined together like that, reflect more on the procedure itself, rather than the devices under test.
Graeme
#11 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 December 2006 - 05:16 PM
Graeme
Graeme,
"without a proper test methodology." With all due respect stopping down a lens 1 stop at a time is hardly rocket science, and very little to go wrong!
Geoff makes it clear that the F900 would do better with one of the Digital Praxis gamma curves but if that is how Sony deliver the camera that is their fault. The Viper would have done far better had a magenta filter been added, again GVG's problem.
I understand the RED sensor is now showing over 11 stops of Dynamic Range, I look forward to seeing the new tests.
Stephen
#12 Graeme Nattress
Graeme Nattress
  • 145 posts
Posted 11 December 2006 - 05:33 PM
Stephen - Exactly. Geoff and David haven't looked at the RAW camera data, but "processed" data. I don't know what they did with my software, or what settings were used to generate the images they used. As you say, other cameras would have performed better under different conditions and I agree.
We have indeed improved the sensor's performance since David used it.
Graeme
#13 Phil Rhodes
  • 12175 posts
Posted 11 December 2006 - 05:47 PM
If these tests were not carried out under matched conditions the results are extremely suspect.
Phil
#14 Graeme Nattress
Graeme Nattress
  • 145 posts
Posted 11 December 2006 - 07:07 PM
Yes Phil! That's totally right. And without any specified repeatable metric for acceptable shadow noise, where do you place black clip??
Graeme
#15 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 December 2006 - 07:11 PM
Phil
Phil,
Unless sombody cheats isn't 1/2 a stop 1/2 a stop? The centre point could be wrong, but the range would still show up.
Stephen
#16 Graeme Nattress
Graeme Nattress
  • 145 posts
Posted 11 December 2006 - 08:31 PM
It all depends on what the image processing did in camera to the highlights and what you define as when the noise swamps shadow detail. That can be very subjective unless you adopt a better testing methodology.
Graeme
#17 Phil Rhodes
  • 12175 posts
Posted 11 December 2006 - 09:53 PM
Further to previous discussion about black clip, yes, depending on how much noise you are willing to put up with the JVC GY-HD101 has about a ten and a half stop range. Only it doesn't, obviously. Yes I have tried it.
Which is, incidentally, about the most accurate way of doing it. Putting your favourite step chart in front of a camera, waving a light meter about and saying "Right, that's obviously an F4" is fraught with difficulty concerning specularity and the inverse square law. But really, the reason for the suspicion is a little scientific principle which states that experiements must be repeatable. We don't know the circumstances under which these tests were done, and considering they were completely different, they're unlikely to be repeatable anyway.
Phil
#18 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 11 December 2006 - 11:31 PM
If all cameras shoot a Macbeth chart, finding a consistant noise level should be an easy prospect sinc eyou could just tell shake or combustion or fusion to analyze a neutral patch for grain characteristics and then find two exposures that give you the same "grain gain" setting.
Edited by Gavin Greenwalt, 11 December 2006 - 11:32 PM.
#19 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 12 December 2006 - 05:11 AM
Hi Gavin,
If your on CML Future cameras, you will know by know that is what Geoff Boyle did.
Stephen
Graeme
Hi Graeme,
Great news, Geoff Boyle is going to test all the cameras he can get, side by side in January, I hope Red is included, with the promised 11+ stops it should kick ass!
Best wishes,
Stephen
#20 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 12 December 2006 - 05:26 AM
Hi Gavin,
Stephen
aha see I knew it sounded like a good idea. ;)
Has he posted more specific testing procedures? Last I had seen it was just a simple 'Here is a graph.' description attached. I'll drop by future and take a look.
- Gavin
