HIGH KEY LIGHTING and LOW KEY LIGHTING
10 replies to this topic
#1 B. Sakthidoss
B. Sakthidoss
  • 22 posts
  • New Delhi,India
Posted 14 December 2006 - 01:35 AM
What is HIGH KEY LIGHTING and LOW KEY LIGHTING ?
What is the purpose of that ?
#2 Kevin Masuda
Kevin Masuda
  • 209 posts
Posted 14 December 2006 - 02:18 AM
High key lighting, you have a much lower contrast ratio which means that between you key light and your fill and fill alone there is little difference. Usually you'd get a 1 to 2 stop difference in that case. In low key you have a much higher contrast ratio, 3 stops or more. For example, say you have a subject that is lit with a split left. Now that subject will have a key on his left face at lets say an F-stop of 2, with an 8:1 contrast ratio. So between your key light, the fill and fill alone you will have 3 stops. So his or her face will be in shadow on the right side, giving more contrast. Low key is usually used for dramatic effect, so purpose is up to the story being told on screen. Did I answer your question?
Kev
#3 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 14 December 2006 - 02:40 AM
A lot of people when they think of High Key, refer to TV sitcoms, which usually work within the 4:1 (2 stop dif) or 2:1 (1 stop dif.) contrast ratio.
Low Key is a really contrasty image, I'd say anything more than an 8:1 (3 stop difference) ratio, where you start to get really deep black and less detail in the shadows.
#4 David Mullen ASC
  • 20072 posts
Posted 14 December 2006 - 02:49 AM
Generally a high key image is predominantly midtones and bright highlights, whereas a low key image is predominantly under key with small areas at key or brighter.
#5 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 14 December 2006 - 03:22 AM
Well put David, I enjoy simpler explanations :)
#6 Kevin Masuda
Kevin Masuda
  • 209 posts
Posted 14 December 2006 - 03:23 AM
David explained it much better than I did.
Kev
#7 Jim Feldspar
Jim Feldspar
  • 288 posts
Posted 14 December 2006 - 11:45 AM
Please forgive me and set me straight if I'm being unduly cranky but I, a faithful member. post a
question in this forum:
need a fast answer on this one
Need help for ext. green screen shot Friday dawn
urgently needing the ingenuity of people on this forum for a real shoot happening tomorrow and I get
79 views and 1 reply (for which I'm grateful) and this person, in his first post, asks a question
that is answered in about a million books on lighting and is the type to which people usually say
do a search or check the archives...and nobody says that while I have read a lot and haven't found
an answer to my question. I'm not looking for a definition that could be found in the index of a
textbook but the expertise, or expert guess, of somebody who has shot a lot.
Even if you think Mini-DV is just wrong for this shot I want to do,
actually, no matter what format I'd be shooting, I'm still not sure how to light the green in the
situation I describe. Thanks.
#8 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 15 December 2006 - 11:18 AM
Hello Mr. Sakthidoss,
Like many terms in film-making, These have more than one application. David's definition is the most common application of "high" and "low" key. Here, they tend to describe the overall look of an image as well as the look of the entire film. It is not just a matter of light values. It, more, has to do with the psychological impact on the viewer. Obviously, brighter scenes for a lighter feel and darker scenes for a heavier feel.
Within that concept, DOPs may or may not use lighting ratios to empahsize mood. While lighting ratios are not necessarily tied to high or low key image strategies, high key to fill lighting ratios lend themselves to low key images and low key to fill light ratios lend themselves to high key images. But, for every application of that rule of thumb there's probably an example of an exception
The assumption that soap operas are lit high key has as much to do with the unavoidable, three (or more) camera/live switching that occurs in TV shooting. Everyone tends to be lit from many directions so that no matter what angle camera gets switched to, there's enough light on the subject. Soap operas compensate by lighting and set "break-downs". They will underlight the backgrounds and use dark set construction and dressings to enhance the low key effect, compensating for the high key subject lighting they are inherently stuck with.
You'd be surprised just how many times I have had to qualify, mid-converstaion, which aspect of "high" or "low" key I was discussing. This, probably more than any other I can recall. It can be a little irksome.
#9 B. Sakthidoss
B. Sakthidoss
  • 22 posts
  • New Delhi,India
Posted 18 December 2006 - 01:16 AM
Kev
Thanks sir
#10 B. Sakthidoss
B. Sakthidoss
  • 22 posts
  • New Delhi,India
Posted 18 December 2006 - 01:27 AM
Thank You Sir, For your explaination, Before Asking this question,I refer Some books, But your explaination is different sir.
#11 Lucita Jones
Lucita Jones
  • 62 posts
  • Chile and Costa Rica
Posted 02 January 2007 - 06:54 PM
Something to consider:
You can make a high key lighting using soft sources (lots of bounce and soft shadows), or using hard light sources that produce strong shadows.
Likewise, you can make low key lighting using both soft and hard light sources.
The way to identify low / kigh key lighting is mostly by the amount of light or dark areas in the image, not by the type of the lighting used.
Hope this adds to the discussion.
LuciTa
LuciTa
