New Carl Zeiss DigiDiopters™ for HD Lenses
No replies to this topic
#1 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 14 December 2006 - 10:30 AM
Band Pro Film & Digital introduces the Carl Zeiss DigiDiopters. This set of high quality diopters in +1 and +2 magnification is optimized to work in conjunction with ZEISS and will also work well with other high-quality 2/3? HD lenses. Ideal for extreme close ups or wide angle shots with a shallow depth of field, Carl Zeiss DigiDiopters attach easily to the front of the lens to provide increased close-focus range and magnification capability.
DigiDiopters employ a unique, achromatic dual-lens assembly to minimize color fringing and spherical aberration --common problems with traditional single lens diopters. The ZEISS optical design ensures a high resolution, high contrast image with consistent precision anywhere in the frame. Carefully selected optical glass elements and the Zeiss proprietary T* anti-reflective coating -- the same coating applied to their DigiPrime®, and DigiZoom? lenses -- reduce light loss and flare while improving transmission for crisp images with saturated colors and accurate blacks. DigiDiopters are designed to optically match the DigiPrime, and DigiZoom?s color balance, contrast, and overall image quality.
Weighing about 10 ounces (285g) each, Zeiss DigiDiopters can be attached to the camera lens ? or to each other ? via a single thumbscrew. A unique self-centering clamping mechanism maintains a proper distance between diopter and lens and keeps them parallel to each other, ensuring optimal image quality. This mounting system puts the least amount of stress on the lens itself, while keeping the DigiDiopters securely in place. It also allows stacking a +1 and +2 diopter together on the front of the lens for a +3 magnification.
