anamorphic super 16
23 replies to this topic
#1 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 14 December 2006 - 05:43 PM
I am going to shoot a short in super 16 format and the producer-director ask me if i can do in in anamorphic s16. I realy have never done something like that i don't even know if there is anamorphic s16 if there are any lenses available for that and what to do at post if i can print on 35mm and wich aspect ratio. I anyone knows or if there is other post.
#2 james smyth
james smyth
  • 48 posts
Posted 14 December 2006 - 06:13 PM
Could they mean have it telecined in NTSC anamorphic? I can't imagine what they could mean by anamorphic 16:9 unless there are they want a 2.35 image or perhaps a lens exists that will make s16 a perfect 16:9.
#3 David Mullen ASC
Posted 14 December 2006 - 07:21 PM
Yes, it's confusing what they mean by "anamorphic" and to achieve what aspect ratio for what final presentation format. Do they mean anamorphic lenses for a blow-up to 35mm anamorphic (2.39 : 1), aka "scope"? Or do they mean for transfer to 16x9 "anamorphic" NTSC/PAL video, which is 1.77 : 1?
#4 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 14 December 2006 - 07:28 PM
The only anamorphic lens I know of are for regular 16mm.
Like this one which is c-mount...
http://cgi.ebay.com/...I...A:IT&ih=012
#5 Ian Marks
Ian Marks
Posted 14 December 2006 - 07:39 PM
Actually, that one is intended to go in front of the taking lens.
#6 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 14 December 2006 - 08:02 PM
I have never used one :D In any case this one looks suspiciously Rube Goldburge to me, coming from a still photography background as I do.
I have always preferred spherical lenses, and not so much for their price, but for their simplicity. I admit simple isn't always better but when ever I see one of these things for sale I always remember the old adage:
There's always a harder way :blink: you just haven't thought of it yet :D
That's not to say that anamorphic lenses don't have anything to recommend them by. If it's the only way to solve the problem, then you just have to go for it.
by the way does any one know what the final aspect ratio would be using this attachment on a super 16 camera? I have to wonder what kind of issues are going to present themselves in post.
#7 Clive Tobin
Clive Tobin
  • 402 posts
  • Spokane Valley, WA, USA
Posted 14 December 2006 - 09:50 PM
...by the way does any one know what the final aspect ratio would be using this attachment on a super 16 camera? I have to wonder what kind of issues are going to present themselves in post.
The normal anamorphic lens used in 16mm projection has a 2:1 expansion ratio. So your 1.7:1 (more or less) super-16 ratio would come out to an awkward 3.4:1 aspect ratio. Other expansion/compression ratios have been made but are uncommon.
#8 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 14 December 2006 - 10:21 PM
3.4:1? That does sound awkward, and possibly expensive to deal with in post.
#9 David Mullen ASC
Posted 14 December 2006 - 11:21 PM
No, not particularly -- whether you were planning on scanning / telecine transferring the Super-16 footage or blowing-up using an optical printer, dealing with a 2x squeezed image is no big deal. The only problem is deciding what to do with the 3.4 : 1 image after it is unsqueezed. Do you want to letterbox the image to 3.4 or crop the sides to 2.35? But there are no additional costs to do this -- cropping & resizing are basic features of the process anyway. And Super-16 is not a projection format, so it has to go thru some sort of conversion or transfer process.
#10 adam berk
adam berk
  • 168 posts
Posted 15 December 2006 - 01:00 AM
so about telecine.... super16 CAN be transferred to anamorphic NTSC? I've only worked on one film project so far (super16) and it was an HD transfer.
If super16 can be transferred anamorphic to ntsc, are there only certain telecines that can do it? Or does any super16 equiped telecine have the capability?
#11 David Mullen ASC
Posted 15 December 2006 - 01:19 AM
It would be a 16x9 transfer, which is "anamorphic" in standard def (NTSC/PAL) but not in HD, which is native 16x9. Most telecine houses can do 16x9 transfers to standard def video.
Your typical widescreen DVD of a theatrical movie is 16x9 "anamorphic" standard def video.
#12 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 15 December 2006 - 03:18 AM
It seems like shooting anamorphic on 16 or Super 16 is a bit of a stretch [ sorry :blink: ] for the medium. Plain old 16 is great and being able to shoot Super 16 on the same camera gives my camera new legs, but I'm not sure if I could get much more with an anamorphic lens.
#13 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 15 December 2006 - 05:24 AM
HI
The produser told me that there is a rendal house in London wich we can rend anamorpic s 16 lenses .
Hi did it on a project that i have never seen that . You thing that there is any opion to blow up squeez s16 to 35mm 1:2,35 ? I can understand transfered to video but direct prinding ?
#14 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 15 December 2006 - 05:58 AM
It's not c-mount. C is only the name of the thing, it's just a ordinary 2xsqueeze adapter mostly used on projectors. As mentioned you would end up with 1:3.32 aspect ratio.
Theoreticly 1.5x squeeze would be best on S16, you end with 1:2.49. Might be a hassle to find such a lens or adapter and have something that's confortable to use. I planed to use a iscorama 1.5x adapter this way but haven't done any tests yet.
After all the discussions I read, the best method to do 1:2.35 on S16mm seems to shoot with normal lenses, and crop it. If you do telecine in SD, transfer it 16/9 anamorphic.
The movie "Aaltra" was done this way. It's B&W, shot on S16 and released in 35mm scope. http://www.imdb.com/title/tt0405629/
#15 A. Whitehouse
A. Whitehouse
  • 267 posts
  • Melbourne
Posted 15 December 2006 - 09:13 AM
I dont know if it helps but I shot a R16mm film using 35mm anamorphics earlier this year and was surprisingly pleased with the results. But as it has been pointed out the negative area is similar to cropping S16mm and we were doing a video finish. As far as blow up I have seen cropped R16mm 2k scanned blowups to anamorphic prints and its amazingly grainy (admittedly that was the nature of the projects style ) but I have also seen incredible stuff 1:2.35 from S16mm. There are not that many (in my experience and admittedly Australia has all of zero anamorphic lenses onshore bar the ones I used I think) PL or bayonet mount anamorphics out there but people in anamorphic friendly territories might know better than me.
If you can find a R16mm Arri out there (or aaton!) then it could yield a good result. Hope this helps...
Sasha
Edited by S. Whitehouse, 15 December 2006 - 09:14 AM.
#16 David Mullen ASC
Posted 15 December 2006 - 11:44 AM
You can use standard 35mm PL-mount 2X anamorphic lenses on a Super-16 camera, but to get to 2.35, you will be using even less width than Regular 16mm in the end, since the unstretched image is 3.36:1 on Super-16 and 2.66 (or 2.74) on Regular 16mm.
In 35mm anamorphic, you only use a negative that is slightly less than 1.20 : 1 to get an image that is slightly less than 2.40 : 1 when unsqueezed. Same would be true for 16mm.
#17 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 15 December 2006 - 04:16 PM
HI
I am a little confused righ now.
the questions are
1) can i shoot s 16 anamorphic?
2) are there any lenses for that? (i have to use only 35mm lenses?)
3) if i unsqueez on transfer to video what aspect ratio do i get?
4) can i print to 35 positive and in what aspect ratio will be after projection?
sorry for my bad English.
#18 David Mullen ASC
Posted 16 December 2006 - 03:37 AM
HI
the questions are
Haven't you been reading all the recent posts on anamorphic 16mm? We just answered those questions!
I'll repeat the info because I like wasting my time...
You can put a 35mm PL-mount anamorphic lens on a Super-16 camera with a PL-mount, but you would have to deal with the fact that almost all cine anamorphic lenses have a 2X horizontal squeeze, and you'd have to deal with the lack of short enough focal lengths to get really wide-angle shots (35mm is the most common of the wide-angle anamorphic lenses, which is not very wide-angle on a 16mm camera -- you'd have to seek out some 28mm anamorphic lenses or wider.)
There are some old anamorphic C-mount lenses that appear time to time on EBay and whatnot.
It's SIMPLE math to figure out the aspect ratio of an image with a 2X squeeze to it when unsqueezed. Super-16 Full Aperture is 1.68 : 1, so a 2X squeezed image on that would become 3.36 : 1 when unsqueezed. Regular 16mm Full Aperture is either 1.33 or 1.37 depending on who you ask, which would be 2.66 or 2.74 when unsqueezed.
Video is either 4x3 (1.33) or 16x9 (1.78) so any other aspect ratios involve letterboxing the transfer within the 4x3 or 16x9 formats.
The 35mm anamorphic projection aperture is slightly less than 1.20 : 1, which is why when the 2X squeezed image is unsqueezed by the standard 2X anamorphic projector lens, the aspect ratio is just under 2.40 : 1.
If you use a standard 2X anamorphic camera lens on a Super-16 or regular 16mm camera, you can blow this up to 35mm and keep the 2X squeeze for anamorphic projection, but you have to decide how to fit the wider image onto the 35mm anamorphic projection aperture. Either you have to crop the sides down to 2.40 : 1, or you have to letterbox the image to hold a wider aspect ratio (like I said, on Super-16 Full Aperture, a 2X anamorphic image gives you a 3.36 : 1 aspect ratio when unsqueezed.)
  • 1
#19 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 16 December 2006 - 10:54 AM
Thank for all the replays.
Sorry David but my English are not the best .Some times my wife translates the posts for me.
BTW. I thing that the best advise is to crop the sides of the frames. I have to start the tests.
#20 David Mullen ASC
Posted 16 December 2006 - 12:30 PM
Unless you want to have anamorphic lens artifacts for the look, cropping the sides of a 3.36 image to get 2.35 won't give you any more quality than cropping the top & bottom of spherical Super-16 to get 2.35.
