Show a Fresnel Key Light
17 replies to this topic
#1 Jonathan Bryant
Jonathan Bryant
  • 284 posts
  • Athens, GA
Posted 16 December 2006 - 02:29 PM
I like to see some setups where you used a Fresnel as the key light. Post a frame and explain the setup.
#2 Jonathan Bryant
Jonathan Bryant
  • 284 posts
  • Athens, GA
Posted 17 December 2006 - 10:09 PM
No one uses Fresnels as key lights? I would like to see what subjects you guys think call for undiffused Fresnels as the key light.
#3 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 18 December 2006 - 02:29 AM
I'll probably have some stuff telecined soon to put up here. My key was an undiffused Arri 650w fresnel.
#4 Jonathan Bryant
Jonathan Bryant
  • 284 posts
  • Athens, GA
Posted 29 December 2006 - 01:09 AM
Come on guys can someone get this thread started? I think it would be interesting to see how people use Fresnels as keylights in their setups.
#5 David Mullen ASC
Posted 29 December 2006 - 01:16 AM
I don't exactly take photos of my set-ups based on the type of unit for the key, and I don't often use a hard key light anyway. I'm not sure half the time you would see a difference between a fresnel keyed close-up versus some other type of hard source light if the light was far enough away.
But if you want to see faces lit directly by fresnels, look at any typical 1940's Hollywood movie.
Here is an example of a photographer working in the style of George Hurrell, who used tungsten fresnels for portrait lighting:
http://www.thestarli...om/portpage.htm
#6 Jonathan Bryant
Jonathan Bryant
  • 284 posts
  • Athens, GA
Posted 29 December 2006 - 01:26 AM
So hardly anyone uses a undiffused Fresnel as a keylight these days? What situations would you use a Fresnel as a key light? What is the most popular way of lighting low key scenes?
#7 David Mullen ASC
Posted 29 December 2006 - 01:55 AM
The only consistenly hard-lit movie I ever shot was "D.E.B.S.", which was meant to have a candy-colored glamour look. Here are two frames (the movie was shot in HD), lit with either a 650w or 1K fresnel key:
Generally you use a hard fresnel for a key light when you are simulating a hard source -- direct sunlight, a spotlight, a distant light, hard moonlight, etc. (unless, as in the case with "D.E.B.S." you are throwing realism out the window). Just think of all the light sources in real life that produce sharp shadows. That's probably when you'd use a direct fresnel.
So if I wanted a window pattern on a wall from moonlight, I would use a fresnel probably (although I sometimes pull-out the fresnel to get a sharper pattern.) If I wanted someone framed by the cut-out pattern of a doorway shadow, as if the light were spilling in from the next room into a dark room, I'd use a fresnel, etc.
#8 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 29 December 2006 - 01:59 AM
Thank you David,
I watched an interview of this guy some time ago but I couldn't remember his name. I am always intrigued by artist keeping old techniques alive.
#9 Ashim
Ashim
  • 81 posts
Posted 29 December 2006 - 02:57 AM
David,
Ive been doin this for some time but have never quite understood as to why pulling out the fresnel lens help in achieve a more harder and crisper shadow.
#10 David Mullen ASC
Posted 29 December 2006 - 03:13 AM
Since there is only a small reflector at the back of a fresnel lamp, when you pull the fresnel, you are mostly getting light from the lamp filament, which is fairly small (unless you go to the really big frensel lamps) so it's a sharp source... but dimmer than if you used the fresnel.
With an open-face lamp, there is a big reflector at the back-end of the lamp and the bulb is often a strip, so you don't get as clean & sharp a shadow unless the lamp is farther away.
#11 Ashim
Ashim
  • 81 posts
Posted 29 December 2006 - 03:31 AM
[quote name='David Mullen ASC' date='Dec 29 2006, 12:13 AM' post='145000']
David Im sorry I didnt quite follow. If Im right the task of a fresnel is to converge the light, then wont removing it only scatter the light even though its a smaller source.
but dimmer than if you used the fresnel... Didnt get a hang of this either!
#12 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 29 December 2006 - 04:02 AM
I'll take a stab at this.
In this wide shot, I used two undiffused fresnels. The key light is a 300w fresnel gelled 1/4 CTB, and the background light is a 1k gelled with primary red. The other light sources are two dimmed PH211 75w practical bulbs (one is out of frame).
In this medium wide shot, I used a 650w fresnel gelled with spring yellow. The background light is a practical bulb which I can't take credit for.
In this close-up, the key is a 1k fresnel bounced into a mirror with water from a shower head running over it to create a rain pattern effect. The backlight is a 650w fresnel.
Don't know if this is what you were thinking of, or whether you simply wanted to see a direct key from a fresnel. I think that's used less often.
#13 Matt Sandstrom
Matt Sandstrom
  • 464 posts
  • Stockholm, Sweden
Posted 29 December 2006 - 07:41 AM
here's a frame. not one i'm extremely proud with but it shows a 650w raw fresnel key. it's emulating a street light that's in the wide shot, and yes i realize that it might be more a cross light than a key in your book. fill is another 650, filtered half blue iirc and bounced off a styrofoam sheet.
/matt
#14 Sing Lo
Sing Lo
  • 39 posts
Posted 30 December 2006 - 08:44 AM
here is a still using undiffused 14" fresnel as key and a small Chimera softbox as fill.
#15 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 30 December 2006 - 11:00 AM
Who's this lady with the mustache?
#16 Jason Maeda
Jason Maeda
  • 361 posts
Posted 30 December 2006 - 03:53 PM
wow.
i mean...wow. that is creepy.
#17 Tim Terner
Tim Terner
  • 340 posts
  • Prague, CZ
Posted 07 January 2007 - 06:12 AM
David, how far from the girl was the fresnel in the shot in the bar and did you use any diffusion ?
#18 David Mullen ASC
Posted 07 January 2007 - 11:53 AM
If you mean diffusion on the fresnel lamp, there wouldn't be much point of me showing the example if I had used diffusion on the lamp -- it could have been any lamp then, open-faced, ellipsoidal, PAR, etc. If you mean diffusion on the camera lens, I may have used a 1/2 Tiffen Soft-FX on the tightest close-ups for that scene, but generally, no, the whole movie was shot clean.
The lamp was probably six feet away or so from the talent, I don't know. Depends on if I had a scrim in it.
