In need of a Perfectone crystal sync motor
#1 Zachary Vex
Zachary Vex
  • 208 posts
Posted 17 December 2006 - 03:07 PM
I need suggestions for places to search for a sync version of the Perfectone motor used in Cameflex CM3 cameras. Even an AC sychro motor would make me happy (if such a thing exists)... it's so easy to generate 60Hz 110VAC now using modern inverters.
Or perhaps there's someone who converts older Perfectone motors to sync? I have both variable-speed and "constant-speed" motors for my CM-3.
Thanks in advance!
#2 Zachary Vex
Zachary Vex
  • 208 posts
Posted 17 December 2006 - 03:56 PM
Update: So far I've contacted Clive at tobincinemasystems.com and AZSpectrum and I'm awaiting replies... but does anyone know of any other possible sources or solutions?
#3 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 18 December 2006 - 04:07 AM
Thanks in advance!
If you can connect of russian 17EP-16APK motor with CM3, you will have crystal synch speeds or can modify on multi speed or speed synthesizer versions.
I know a modified Arri 2C cameras with 17EP-16 APK crystal synch motor.
