Homemade Diffusion Gel
7 replies to this topic
#1 David Calson
David Calson
  • 269 posts
  • Georgia
Posted 17 December 2006 - 07:29 PM
Hi, just doing some low budget tutorial videos and wondered if there's diffusion gel substitute you could concoct. Tried wax paper but it wasn't strong enough, thanks.
#2 Chris Pritzlaff
Chris Pritzlaff
  • 187 posts
Posted 17 December 2006 - 07:36 PM
diffusion is really not that expensive. Just get the real thing. You risk setting substitutes on fire if you try something that is not designed for high temp.
#3 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 17 December 2006 - 08:08 PM
I second that. At $5-$7 per sheet, it would be much wiser to buy some. Plus, you'll have it for next time.
#4 David Mullen ASC
Posted 17 December 2006 - 08:13 PM
If you put the paper on frames farther from the light, to keep the heat down, something like Tracing Paper (1000H) works well for a heavier diffusion. You can also bounce the light instead.
But you could but a few sheets of diffusion gel (24"x36" I think) for maybe $5 each.
Just the other day, we threw a semi-clear plastic grocery store bag over a B-camera camera to protect it from some splattering food (it wasn't rolling during the shot, just the A-camera) and it was the most interesting diffusion effect on the video tap monitor... Sort of a Fog #10, I suppose.
#5 Jonathan Bryant
Jonathan Bryant
  • 284 posts
  • Athens, GA
Posted 17 December 2006 - 10:47 PM
Fabric softner sheets work great. Just make sure I get credit for this secret :)
#6 Mike Williamson
Mike Williamson
  • 534 posts
Posted 18 December 2006 - 08:35 PM
For gels and diff, I get stuff from The Expendables Recycler. Not free, but it's cheaper than setting locations on fire.
#7 Chris Cooke
Chris Cooke
  • 246 posts
  • Lethbridge, AB Canada
Posted 18 December 2006 - 11:31 PM
Try buying a white shower curtain liner. I have used this for quite a few scenes where it's the perfect size and weight of diffusion that I need. They're less than $10 and work well. Just make sure that the curtain is far enough from your source (you'll get a softer effect this way because it fills up the frame and it won't catch fire).
#8 Daniel Carruthers
Daniel Carruthers
  • 334 posts
  • Canada
Posted 20 December 2006 - 11:41 PM
I like to use bakEing sheet paper, just make sure its not waxpaper!
baking sheet paper works great it can withstand the heat from a redhead.
and it only cost me 2$ for an entire roll at some dollor store, cant remember the brand? it came in a yellow box.
