What is an "Optical Low Pass Filter"
#1 Carl Brighton
Carl Brighton
  • 222 posts
Posted 29 December 2006 - 05:40 AM
I've read that all video and digital still cameras have a thing called an "optical low pass filter" fitted to the sensor chips. The effect of this is supposedly like putting a sheet of tracing paper over the sensor.
Can anybody tell me what this actually for, and will the camera work without it?
  • 20069 posts
Posted 29 December 2006 - 12:39 PM
When fine edges and lines of a photographic subject hit the fine grid pattern of the sensor photosites, you get a phenomenon called "aliasing" -- moire-patterning and "twitter" along the edges. The solution has generally been to slightly diffuse the image before it hits the sensor to reduce the aliasing artifacts, hence why the low-pass optical filter is also called an anti-aliasing filter. I assume the higher the resolution of the camera, the more detail it can handle before aliasing, and the less-strong the low-pass optical filter is.
http://en.wikipedia....aliasing_filter
Film doesn't have a rigid grid of photosites, it has random pattern of silver halide grains, so it does not have this problem (until you transfer film to video...)
