new ASA rating for Z1 with Mini35
#1 Nadav Hekselman
Nadav Hekselman
  • 68 posts
Posted 01 January 2007 - 09:05 AM
Hi all,
Im about to start shooting a drama-short using the mini35 adaptor and HDV-Z1.
i rated the camera at about 160 ASA but when i put on the Adaptor i have to zoom in to full tele and i end up with 2.8f on the Z1 lens. how should i rate the camera now than?
It seems logical to me that if the most open iris on the Z1 is 1.6 and i take it down to 2.8, i lose 1 and 2/3 stops, which take the 160 ASA down to 50 ASA, and i use the 35 lenses iris for calcualting... but this doesnt seem right when i measure the light. it seems overexposed. i guess the adaptor itself takes out some light and i need to rate it even less.... cant find nothing about it on p+s technick site...
can anyone help?
#2 Matt Sandstrom
Matt Sandstrom
  • 464 posts
  • Stockholm, Sweden
Posted 01 January 2007 - 05:38 PM
you mean it seems underexposed, right? anyway, just use whatever asa setting that works. shoot a grey card and check the levels if you're uncertain. there's no mathematical formula that can ever give you the correct light loss factor of a 35mm adapter.
also, a much better strategy for using such an adapter is to set the f-stop on the 35mm lens to a fixed number and adjust the camera aperture instead. much more control without any weird dof changes, plus at some apertures you may start seeing the grain in the ground glass.
/matt
