BATTEN STRIPS!
#1 Sol Train Saihati
Sol Train Saihati
  • 96 posts
Posted 02 January 2007 - 01:52 PM
Happy New Year all, :D
Does anyone have any good designs/ideas for a constructing Batten Strips?
#2 Rob van Gelder
Rob van Gelder
  • 158 posts
  • Steadicam Operator
  • Bangkok, Thailand
Posted 04 January 2007 - 04:34 PM
forgive my lack of knowledge, but what are they? Batten Strips?
#3 David Mullen ASC
Posted 04 January 2007 - 06:23 PM
The most simple design is a strip of lightweight wood with a row of lightbulb sockets attached to it.
#4 timHealy
timHealy
  • 1262 posts
Posted 04 January 2007 - 06:25 PM
Batten strips are pretty easy.
Usually pieces of wood referred to as batten are kind of a rough stock of wood used for all sorts of purposes. Typically they are 1 and 1/4 inches thick and 2 and a half inches wide. or something like that. I think 8 foot and 4 foot lengths are most popular, that I have seen. One could make one longer if needed. 8 foot lengths typically have one porcelain socket per foot with two circuits alternating each socket. 4 foot batt strips usually have one curcuit but you can put two if you like. Afetr wiring them be careful to insulate the exposed connectors. I try and use liquid electrical tape.
Best
Tim
#5 timHealy
timHealy
  • 1262 posts
Posted 04 January 2007 - 07:06 PM
I should have mentioned that one should use 12 gauge wire and 20 amp hubbles and one can use 4 500 watt (or less) bulbs on each 4 socket curcuit.
You can use braided wire and a wires tipper to remove insulation where it lines up with a connector. Or if you want to gate a little more secure, one can use crimp connectors, but that takes a little more work and supplies.
Storing them can be a problem as eventually the fragile porcelain sockets may be damaged.
Best
Tim
