Digital Slow Motion
#1 Sol Train Saihati
Sol Train Saihati
  • 96 posts
Posted 08 January 2007 - 08:24 AM
Simple question: Is it necessary to open the aperture when shooting slow motion on digital formats?
#2 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 08 January 2007 - 08:59 AM
if you shoot with a video camera that is only capable of 25fps or 50i and you add the slowmotion in post, then no.
if you shoot with a video camera capable of variable frame rates like the hvx200/varicam/etc then you have to compensate for the exposure loss one way or another. you could do this opening the iris, adding more light or using digital gain.
#3 Troy Warr
Troy Warr
  • 212 posts
  • Austin, TX, USA
Posted 08 January 2007 - 09:08 AM
Simple answer is yes. The laws of physics still dictate that each time you half the exposure time of the CCD/CMOS, you have to double the light passing through the aperture. In this sense digital is no different than film.
But, in practice, I don't think it can be quite that simple. I think it also depends on how the camera generates its slow motion, which isn't always in exactly the same way as a film-based camera. The Sony HVR-V1U, for example, shoots a burst of 240 fields (not frames) per second, so I would assume (and somebody please correct me if I'm wrong here) that you wouldn't need to compensate for the reduced shutter speed by opening the aperture as much as with a film camera, on that particular camera. Ultimately, though, you're still bound to the laws of physics.
#4 David Mullen ASC
  • 20068 posts
Posted 08 January 2007 - 12:51 PM
If you change the shutter speed or frame rate in the camera, you have to compensate for the exposure. But if you don't and create the slow-motion entirely in post, then you don't have to adjust the exposure.
However, most people converting 60i/50i footage to slow-motion in post will at least shorten the shutter speed to reduce motion blur on each field, like to something like 1/100th of a second -- in which case you would have to account for the exposure loss from shortening the shutter speed.
