China Balls
#1 Chris Cooke
Chris Cooke
  • 246 posts
  • Lethbridge, AB Canada
Posted 08 January 2007 - 10:47 AM
I bought a large china ball from Ikea the other day and fitted it with a 500w EHD bulb from osram. I then proceeded to put 250 inside the ball as a heat barrier so that the paper lantern would not burn. The light from it looks good but I'm still a little nervous to use it for more than a couple of minutes at a time. What are some ways that you guys have made fire safe china balls and fitted them with large bulbs.
#2 Phil Rhodes
  • 12171 posts
Posted 08 January 2007 - 11:25 AM
Have you actually tested the ball for flammability? In any reasonably civilised country I assume there would be codes regarding the combustibility of lighting equipment. Even if not, you can usually get spray-on fire retardant, and it might be a good idea to give it a dousing anyway (does smell of cat's piss, but it stops things catching on fire).
I once melted a big hole in a polyboard with a 2.5K HMI...
Phil
#3 Wendell_Greene
Wendell_Greene
  • 545 posts
Posted 08 January 2007 - 12:07 PM
This works great:
Jem Paper Lantern Harps- Spec Sheet
Jem PaperLantern Harps- Main Page
