Super Wide Problem
9 replies to this topic
#1 Christopher Wedding
Christopher Wedding
Posted 10 January 2007 - 02:20 AM
So I encountered a funny problem while shooting a 2 camera Betacam job today. Our superwide Canon 4.5 was 'seeing' itself b/c it was TOO wide. I'm wondering why that was. I couldn't believe the lens was designed to 'see' it self. We had to zoom in all the way to around 15mm to lose all of the vignetting caused by the lens. Was there something I missed? I tried flipping the doubler on and off to see if the trigger was stuck, I tried everything else I can think of that might be getting in the way...any ideas? Is it possible some glass element got loose and caused the lens to 'see' more than usual?
Any insight would be greatly appreciated. Besides feeling a bit red from this happening in front of a client, Really I'm hoping there's nothing wrong with the lens.
Best,
Chris
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 10 January 2007 - 03:04 AM
Vignetting usually happens with cheap fisheyes that aren't constructed wide enough for the camera's own elements or even in some cases, its own.
In this News posting at this website you can see an example of a good fisheye/extreme wide angle lens: http://cinematograph...showtopic=19182
You can see that it expands out and above & beyond the camera's own lens elements to prevent any vignetting.
Edited by Jonathan Bowerbank, 10 January 2007 - 03:05 AM.
#3 Jim Feldspar
Jim Feldspar
  • 288 posts
Posted 10 January 2007 - 08:25 AM
Best,
Chris
" tried flipping the doubler on and off to see if the trigger was stuck"
I've used a fair amount of video cameras but what is the "doubler" ?
#4 Christopher Wedding
Christopher Wedding
Posted 10 January 2007 - 10:51 AM
It doubles the focal length of the lens, with a loss of light however.
Also, this lens I was using wasn't cheaply constructed. I've used Canon 4.5s plenty with no problem. And this was the same type of lens. Anyone have an idea of what the problem is?
#5 Broatch Berry
Broatch Berry
  • 10 posts
Posted 22 January 2007 - 02:15 PM
I think the problem might be that the Canon len's has a crossover for use on cameras that have the option to shoot 4x3 or 16x9, if I remember the last Canon lens I used with the crossover had a small dial that said
16x9-4x3 to use this function and how it worked was when you were in the 4x3 mode on a 16x9 camera, you could dial in the crossover to give you the 20% you lose on your wide end on the camera in the 4x3 mode! but if you went back to 16x9 mode on the camera and you did not set the crossover back to 16x9 on the dial you would get the vignette in lens from the crossover bieing on for the 4x3 setting.
I hope this helps
Broatch
#6 Broatch Berry
Broatch Berry
  • 10 posts
Posted 22 January 2007 - 02:33 PM
I hope this helps
Broatch
So if you are shooting with a none widescreen betacam camera (4x3) and have a crossover lens for dealing with the 20% loss on the wide with a widescreen camera shooting 4x3, leave the crossover off! or the doubler crossover will vignette your lens on your 4x3 only betacam.
I think that what I wanted to say
Broatch
#7 Daniel Sheehy
Daniel Sheehy
  • 407 posts
  • Brisbane
Posted 22 January 2007 - 03:49 PM
2x focal length extender.
The lens is for the appropriate sensor size...?
#8 Christopher Wedding
Christopher Wedding
Posted 24 January 2007 - 02:06 PM
So I found out the problem. First of all, you are correct that this was a cross-over lens. Some of these lenses have a design 'flaw' in that element can get 'stuck' between the 16:9 and 4:3 mode b/c of something with the doubler mechanism thus causing a vignetting problem. What you have to do is a two step solution. First turn the dial over to 16:9 on the cross-over and then flip the doubler on and off a few times. Then switch back to 4:3 mode and the vignetting is gone. Also, I should mention the lens was actually a Fuginon 4.8 not a Canon 4.5. Sorry for the confusion and thanks for the responses!
#9 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 24 January 2007 - 02:21 PM
Funky
#10 Brian Drysdale
  • 5194 posts
Posted 24 January 2007 - 04:39 PM
Funky
There was a brief fashion of shooting shots with the doubler (x2) in the half way position, so that you had the wacky effect of two images superimposed at difference focal lengths. You could get some neat effects.
