Just bought an Arrilite 1k light kit. Question
#1 Donnie Lewis
Donnie Lewis
  • 7 posts
Posted 11 January 2007 - 05:03 PM
The protective mesh and scrims it came with seem to heat up and smoke. Is that normal?
http://www.bhphotovi...oughType=search
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 11 January 2007 - 05:37 PM
Hmmm, could just be some acrylic coating or something to protect the metal until it's been put to use.
To avoid a smoky or smelly set, you might just wanna run the lights for a while in a well ventilated area to burn all that stuff off.
Otherwise, it's not a big deal...unless the wiring inside the light is smoking! he he
#3 David Mullen ASC
  • 20068 posts
Posted 11 January 2007 - 06:11 PM
New scrims tend to smoke a little and smell bad until whatever oils and whatnot left on them burn off. Of course, smoke coming from inside the light itself is a bad sign...
#4 Donnie Lewis
Donnie Lewis
  • 7 posts
Posted 11 January 2007 - 09:41 PM
Thats what I thought, too. The lights are fine. The smoking stopped when I took the scrims off. Thanks. I'll let it run for a few minutes until it stops smoking. It'll take a while, as there are four scrims and three protective meshes. Anyone know of a way I can wipe the coating off?
#5 JD Hartman
JD Hartman
  • 1763 posts
  • Edison, N.J. U.S.A.
Posted 12 January 2007 - 11:32 AM
David id right, residue from the manufacturing process. Probably petroleum based, a soak in dish detergent or de-greaser, 409, Fantastic, Oil-Eater should do. Rinse them and then dry quickly in from of a fan or in a warm oven.
