CP motor for eclair ACL
#1 marc barbé
marc barbé
  • 82 posts
Posted 12 January 2007 - 09:48 PM
Has anybody out there experienced the 24-48ips CP motor made for the Eclair ACL?.
Marc
#2 Kenny N Suleimanagich
  • 902 posts
Posted 12 January 2007 - 11:39 PM
If you're trying to bring back from the dead an old outboard motor for the ACL , I would just recommend scrapping it and getting a motor from Tobin Cinema Systems, they're the best in older camera syncmotor systems
#3 marc barbé
marc barbé
  • 82 posts
Posted 13 January 2007 - 12:07 PM
Thanks. They don't seem to have anything for ACLs, though.
I am just wondering if the 24-48ips CP motor is as powerfull as the original Eclair 12-75ips motor. I'm concerned about the 4OOft mags and battery drain.
Marc.
#4 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 24 January 2007 - 03:29 AM
Marc.
Yes, you are right to be concerned. CP modified original ACL 1 and 1.5 motors to go under and over 24 fps, which is the speed they were designed to run at. CP modified motors are not "heavy duty" as the ACL 2 motor is, or as expensive and hard to find. This motor will run 400' loads with ease and will not flicker as the older and/ or modified motors did when strained by the larger loads. This generally would happen in longer takes, after a couple of minutes of the camera being run without stoping. On shorter takes (around a minute), done after the camera motor has cooled down, you may be able to get away with not getting flicker.
I own an ACL with a 8-48 fps CP modified motor. The previous owner claims it runs 400' loads flickerlessly with the supplied 400' mags. I have no reason not to believe him, but I sincerely doubt it can keep up. I have not put the modified motor to test myslef, however, as I also own 3- 200' mags and prefer using them. I shoot short ends or A-minima 200' loads with it, though. For 400' loads I use my Aaton LTR 7, which has no problem keeping up, of course.
I don't know about the battery drain, though. My battery is a huge custom made Powersonic block that, aside from being big and heavy, simply rocks on long and steady power supply chores.
Best,
Saulie
#5 marc barbé
marc barbé
  • 82 posts
Posted 25 January 2007 - 03:07 PM
Marc.
Best,
Saulie
Thank you Saulie, that's very enlightening. I think I'll wait for an ACL2 motor to come along.
Regards,
Marc.
#6 Ian Marks
Ian Marks
Posted 25 January 2007 - 05:39 PM
Clive Tobin discontinued his ACL motor years ago - I don't think it was cost-effective for him to make them given the number of ACL's in use. I obtained one new for much less than the cost of a used CP or ACL2 motor, but the Tobin motor is considerably bulkier than those and noisier to boot. Does the trick, though.
