Super 16mm Krasnogorsk-3 footage shot with Peleng 8mm
30 replies to this topic
#1 Andy Boreham
Andy Boreham
  • 19 posts
  • Wellington, New Zealand
Posted 14 January 2007 - 07:55 PM
Some clips from a test reel I shot on a recently acquired Super 16mm modified K3.
Kodak Vision stock... telecined with Spirit Datacine.
Go to http://www.frozenflameweb.com/k3s16 to download the footage :)
#2 Andy Boreham
Andy Boreham
  • 19 posts
Posted 14 January 2007 - 08:44 PM
Oops - file wasn't attached :blink: Should work now.
#3 adam berk
adam berk
  • 168 posts
Posted 14 January 2007 - 10:10 PM
awesome....
is there anyway you could post here or on that site some full res stills? I'd be most interested in seeing some full res grabs from the CU of the boy towards the end...the same shot as the pic on the right on your page
#4 steve hyde
steve hyde
  • 446 posts
  • Seattle
Posted 14 January 2007 - 10:55 PM
...I think the problem is the lens. Looks like worn elements to me. Couldn't be the telecine if you used a Spirit and if the film stock is fresh you should get way more color out of it. Did you test any other lenses with this camera?
Steve
#5 Andy Boreham
Andy Boreham
  • 19 posts
Posted 14 January 2007 - 11:03 PM
Steve
Yeah, tested a few others. The 'problem' with the film stock is that it's actually Tungsten balanced without any correction filters.
The test was really to see which lens covered the S16 frame etc, so getting a good image wasn't really an issue - which is why a lot of the shots are less than well exposed :)
awesome....
Sure thing, will do that tomorrow...
#6 steve hyde
steve hyde
  • 446 posts
  • Seattle
Posted 14 January 2007 - 11:12 PM
a cheaper way to test lens coverage is to take the lens down to your camera shop and ask them to project charts though it. It's an easy film-free way to test if a lens will cover the S16 frame..
Steve
#7 Andy Boreham
Andy Boreham
  • 19 posts
Posted 15 January 2007 - 05:26 PM
awesome....
That frame should be on the site now, http://www.frozenflameweb.com/k3s16 :)
Edited by Andy Boreham, 15 January 2007 - 05:28 PM.
#8 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 16 January 2007 - 10:02 AM
Very fun lens. That's one of the great things about the K3, picking up relatively inexpensive lenses for effects.
Interesting that the distortions seemed to be roughly centered; I would have expected them to be slightly off since the lens/gate isn't recentered, the gate is just widened on one side.
Another lens worth looking into is the Zenitar 16mm which you can buy new from Russian camera importers. It also covers the full S16 frame, is wider than the Meteor Zoom, and much less distortion than the Peleng.
Also, find a 50mm Pentax Super Takumar 1.4 for really sharp (and low light) shots. Sometimes you have to buy a camera too to get this lens but then its fun to have a 35mm still camera to mount all these M42 lenses without adapters.
#9 Andy Boreham
Andy Boreham
  • 19 posts
Posted 16 January 2007 - 04:19 PM
Oh excellent, I'll keep an eye out for that Zenitar lens - sounds great! I really hate the distortion on the Peleng but it *could* be useful in some situations...
By the way, the lens / viewfinder on my K3 has been re-centred.
#10 Robert Houllahan
Robert Houllahan
  • 1627 posts
  • Providence R.I.
Posted 17 January 2007 - 09:25 PM
Did they do a full super16 mod to this camera, there seems to be an emulsion mark in the super16 area of the footage. When converting a camera to Super you have to mill all of the surfaces which come into contact with the area of the film just widening the gate will not assure a scratch free negative.
-Rob-
BTW I use my Peleng 8mm lens in a nikon mount on my eyemo, now thats wide! O
#11 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 17 January 2007 - 09:33 PM
Out of curiosity, is the 16mm Zenitar lens that much wider than the 17mm end of the 17-69 meteor zoom? Are we only talking about a slight difference or a considerable difference in field of view? There is only 1mm in difference in focal length but then again, the Zenitar is a fisheye lens.
#12 Andy Boreham
Andy Boreham
  • 19 posts
Posted 18 January 2007 - 03:04 AM
-Rob-
Yeah there is scratching on the cell side of the film so I might have to get things looked at to find out what is going on... I really don't know exactly what was done to this camera other than that the lens and viewfinder were centred, the gate was widened and the loop formers were removed...
#13 Robert Houllahan
Robert Houllahan
  • 1627 posts
  • Providence R.I.
Posted 18 January 2007 - 05:42 AM
You might want to look at the gate guides on the emulsion side if the rail on the S16 side has not been milled to the S16 dimensions it will likely scratch the emulsion because of the pressure being applied by the pressure plate. The other culprits might be the clip in rollers which hold the film around the center ssprocket.
-Rob-
#14 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 18 January 2007 - 03:50 PM
The Zenitar is slightly wider obviously than the Meteror at 17, but it covers the entire Super 16 frame while the Meteor lens only covers it above 24 or so.
The results aren't fisheye on a 16mm camera... only on a 35mm camera. The distortions are there, but MUCH less than the Peleng. Keep in mind that on the Peleng if you use it on a 35mm, its a TRUE fish eye and you get a completely round shot while 16mm cameras basically use the center "half" of the coverage area.
#15 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 19 January 2007 - 09:45 AM
"Keep in mind that on the Peleng if you use it on a 35mm, its a TRUE fish eye and you get a completely round shot while 16mm cameras basically use the center "half" of the coverage area."
Correct.
#16 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 19 January 2007 - 05:53 PM
I checked both lenses and as expected there is very little difference in viewing area. The only advantage on the 16mm Zenitar is the full Super 16 coverage and it is smaller & lighter. Not even sure if it would be sharper. But if you have a Super 16 K3 I highly recommend it.
#17 Scott Cohen
Scott Cohen
  • 34 posts
Posted 20 January 2007 - 09:43 PM
This is a consumer camera that can produce professional results.
For the money you'd spend to re-center the lens, take out the gate rail (beyond just widening it the aperture) and then build a viewfinder system that really covers the full S16 apertue you'd be better off buying an modified Eclair NPR.
For people who want to get pro results do these simple steps andd save your money for film.
1. Buy a working K3
2. Have the gate widened to Super 16mm
3. Have the loop formers removed.
Leave the rollers alone (they are plastic and won't scratch your film). Leave the viewfinder alone, a quick pan before shooting will let you know what you will have in the extra area. Don't re-center the lens, incredibly waste of money.
AND... MOST IMPORTANTLY...
Before you load every 100 foot spool. Take your pinky finger and run it back in forth between where your nose meets your face.
Liberally apply this "nose grease" to the film gate, concentrating on the side of the gate that has been widened.
As long as you don't have a small bur on your gate surface... A single application of "nose grease" will let the film pass over the wider gate rail (wider than the widened apertue) without any scratching issues.
You have an emulsion pressure mark, not a scratch.
"Nose grease" makes a $500 dollar Super 16mm K3 solid gold!!!
SC
#18 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 21 January 2007 - 05:36 AM
I own this lens, but it's in K mount (bayonet). Did Pentax make this lens in M42 mount as well? I have a 55mm f1.8 regular Takumar (no super-multi-coating) in M42, but it's not as sharp as the other lens.
#19 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 January 2007 - 11:56 AM
Thats a 35mm still camera your talking about, on a motion picture 35mm its not a true fish eye.
Stephen
#20 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 21 January 2007 - 08:33 PM
yes.
There are both "regular" and "super multi coated takumar" versions in screw mount.
One thing to watch is that many of them used Thorium Glass, which can turn yellow in time. I cleared mine up by leaving it in the sun for a few days! (although I had one follow swear that that would change the refractive index so much that the lens would not work - Seems to work OK :) )
