4 pin XLR configuration
#1 Chris_Burket
Chris_Burket
  • 77 posts
Posted 19 January 2007 - 05:15 AM
I am getting ready to build some 12volt batteries for my Konvas 2m motor and I'm planning on wiring them all up with 4 pin XLR plugs. I was just wondering what the normal configuration is for 4 pin XLR. Which pins are negative or positive? I've heard 1 is positive, 4 is negative, and 2 and 3 are empty. Is that correct?
#2 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 19 January 2007 - 05:30 AM
Wrong way round - pin 1 is -ve, pin 4 +ve. 2 and 3 not connected.
#3 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 19 January 2007 - 08:12 AM
I second Luke.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 19 January 2007 - 08:34 AM
Hi Luke,
That will work with a Sony camera too!
Stephen
#5 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 19 January 2007 - 01:27 PM
If your Konvas have 17EP-16 APK motor, you must be very careful with polarity of battery.
The many 17EP-16 APK motor burn down after connect battery with reversal polarity.
About 4 pin XLR connetor, I have information :
pin #1 ( - ), negative battery
pin #2 ( +) 16 v battery
pin #3 ( + ) 24 v battery
pin #4 ( + ) 12 v battery.
If you will use of 12 v battery, you need use pin 1 ( - ) negative , pin 4 ( + ) positive battery, pin 2, 3 not use.
