Soft Box kit on eBay...
#1 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 19 January 2007 - 10:52 PM
Whaddaya guys think? It's so cheap it's tempting, but I don't know :/
http://cgi.ebay.com/...1QQcmdZViewItem
#2 David Sweetman
David Sweetman
  • 757 posts
Posted 20 January 2007 - 12:46 AM
That 'Amvona' equipment is cheaply built but functional; I've got some of their c-stands and combo stands because they're so much cheaper than Matthews and good enough for my purposes. I've never had any problems in over a year, but they're definitely weaker, so you do get what you pay for. In my case, the savings were well worth it.
#3 Mitch Lusas
Mitch Lusas
  • 99 posts
Posted 20 January 2007 - 03:42 AM
Buying cheap is expensive. Amvona has some okay equipment. But that equipment was based on designs they stole from companies like Bogen. In the long run you'll be happier purchasing an Arri or even (if you shoot quick and dirty) Lowell kit. If you're looking for cheap, you might be able to find an old RedHead Kit and build a SoftBox onto the barndoors using Nylon Ripstop and FoamCore.
#4 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 20 January 2007 - 08:29 PM
cool cool, I figured as much. I'd never heard of the brand before, so thanks for your input :)
Hoping to get a good Arri fresnel kit and maybe some Photoflex or Chimeras sometime this year.
Anyone know where I could find some Briese lights here in CA?
#5 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 21 January 2007 - 06:05 AM
I have three of the Amvona/Dynaphos softboxes. They're very well made, comparable to a Chimera, but a fraction of the cost. I haven't used the Amvona lights, but they appear to be copies of the Photoflex Starlite QL. The speedring that they supply will only fit these lamps. If you want to use the softboxes with other lamps you'll need to buy the correct ring.
On the whole, I'd say don't buy one of their kits. Just get a couple of the softboxes and buy a speedring for your Arris from B&H.
#6 Evan Phan
Evan Phan
  • 10 posts
Posted 23 January 2007 - 10:04 PM
It all depends on your budget.
If you're in a situation where buying the standard Arri and/or Chimeras means using a lot of your budget, I'd say definitely go for a softbox or two from Amvona, like mentioned above. The kits might be a bit much. I've bought an Amvona large softbox from ebay and have used it for 2 years. It isn't the QUICKEST to setup, but no longer than 5 minutes in skilled hands. But they're definitely sufficiently functional. Large diffused sources are large diffused sources anyway you cut, as long as you know how to use them. I'd use that extra cash to buy/rent other things the production would surely need like c-stand kits, gels, other expendable grip equipment.
If budget isn't a big issue on the other hand, I'd just go straight for Kino Banks.
#7 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 24 January 2007 - 06:25 AM
No offense, but what are you doing that takes five minutes? Mine take less than 30 seconds to set!
Kinos are very nice, but all they do is soft light. You still have to carry fresnels or open-face lamps around with you. If you have the space, money and crew to carry lots of lights, fine, but otherwise a fresnel kit with softboxes or diff frames is much more flexible.
