Original negative used for VHS / DVD release?
#1 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 20 January 2007 - 12:17 AM
First off, I must say that I am vaguely familiar with the basic steps involved in producing a reversal print from a movie for theatrical projection. As I understand, after the negative is developed, a duplicate copy of the negative is made and reversal prints are made from the duplicate negative so as not to harm the precious camera original.
However, when releasing a movie for VHS or DVD release, is it standard practise to telecine the original negative or the duplicate copy of the negative? I am assuming the original negative is scanned for best quality but I can't help but think of the risks involved with damage, scratching and possible loss in transport. I know these risks are minimal as the negs are handled by professionals but we are all human afterall and humans make mistakes. Could be a worry for a big budget Hollywood production.
  • 20069 posts
Posted 20 January 2007 - 12:43 AM
Generally you'd make a color interpositive (IP) off of the original negative for protection, and if you had even more money, you'd make b&w separations (YCM's).
But more movies and TV's created from scans or telecine transfers of the original negative, that are only finished to video, often there is no protection film master made. It's slightly less necessary since the negative is not being handled much, maybe two or more passes in a telecine or scanner at the most.
There used to be a practice of going back and conforming the original camera rolls into an edited master, after a TV show was finished on video, but I'm not sure how many do that anymore, not with so many electronic editing tricks being used in the cut. Maybe they just vault the camera rolls and leave it at that. Mike Most?
I'm not sure what you mean by the term "reversal print" -- generally I think that means a reversal copy of a reversal original, for projection.
#3 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 20 January 2007 - 11:57 PM
"I'm not sure what you mean by the term "reversal print" -- generally I think that means a reversal copy of a reversal original, for projection."
I'm referring to the positive print made from the duplicate of the negative - for projection at the cinema. What would be the genuine name for this print? Additionally, what would be the genuine name for the 'duplicate negative'?
#4 David Mullen ASC
  • 20069 posts
Posted 21 January 2007 - 02:21 AM
It would go:
35mm original neg --> print OR
35mm original neg --> interpositive (I.P.) --> dupe negative (sometimes called an internegative, or I.N., but there is some disagreement on that) --> print
The interpositive and internegative / dupe negative are the same intermediate lab stock. Each generation creates the opposite in density of the previous generation -- they are all "negative" stocks in that sense, so a negative picture of a negative is a positive image, etc.
It's a "print" whether or not it's off of the original negative or dupe negative, although sometimes the ones off of the dupe negative are called release prints, and ones off of the original negatives are called show prints or E.K. prints. But one could make one's release prints off of the original negative. There are lots of terms for prints: composite prints (ones with a soundtrack), answer print (for timing), check print (a silent one-light print usually of a timed dupe negative / I.N.), etc. And the last answer print, if it's a composite print, may end up being your show print, etc.
But reversal print is something else because it uses reversal stock to make a positive print of a positive original for projection.
#5 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 22 January 2007 - 03:35 PM
the practice at the lab is that internegative and interpositive are color.
A dupe negative is B/W and is made from a fine grain master (FGM).
To add to the confusion, I/Ns from Technicolor were often labeled I/Ds.
Which I'm guessing is intermediate dupe.
Edited by Leo Anthony Vale, 22 January 2007 - 03:37 PM.
