Canon GL-2 and 24fps
#1 Ray Gonzales
Ray Gonzales
  • 9 posts
  • Irvine, CA... the wanabee real OC
Posted 22 January 2007 - 03:02 AM
I am having a hard time finding information on whether or not the GL-2 has a 24fps mode. I guess im hoping that one guy out there who has one will see this and give me a quick yes or no answer.
#2 Bryan Darling
Bryan Darling
  • 227 posts
  • Sacramento, CA
Posted 22 January 2007 - 02:13 PM
No, it does not have a 24p or 24 frame mode. It does have a "Frame" mode in which it essentially becomes 30fps progressive. It takes the first field of the video frame and duplicates it for the second field. I have used it many times because I like the "look" it gives.
#3 Ray Gonzales
Ray Gonzales
  • 9 posts
Posted 22 January 2007 - 11:17 PM
Thanks Bryan!!!!!
Knowing this information does change my plans though. I guess the panasonic is the way to go huh. Too bad as the GL-2 is about $1k less. Oh well, you get what you pay for right :D
#4 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 23 January 2007 - 08:28 AM
Thanks Bryan!!!!!
Or you can simply do the 24p gimmick in post with more control and more otions than you can in camera and save the $1k. I do about 1/2 of my video productions where budget might not dictate a 24p camerqa using Nattress filters and the results are no worse than the best 24p camera out there. I think too many folks don't know that such an effect does not have to be done in camera to be done well.
Edited by Walter Graff, 23 January 2007 - 08:29 AM.
#5 Igor Trajkovski
Igor Trajkovski
  • 311 posts
  • Macedonia
Posted 30 January 2007 - 08:46 PM
As previuosly said, GL2 does not have 24p.
It has 30fps in FRAME movie mode.
It does not simply double the one field.
In Adam Wilt's words:
These cameras get their "proscan" images not by truly perfoming progressive readout on the chips, but rather by offsetting the green CCD's read timing by one scanline during readout -- vertical pixel-shift, if you will. In essence, an even field from R & B CCDs is blended with an odd field from the G CCD, giving you a frame that has the scanlines for both fields captured at the same instant in time. This gives a definite improvement over mere field-doubled "frames", but it's not as sharp vertically as true proscan. Each "scanline" is actually composed of two scanlines from each chip, so there is some softening vertically; also, the effective chroma resolution is halved vertically.
From his site:
Adam Wilt - DV-FAQ-etc. filmlook
I own a XM2 - the European Version.
Normal Mode 50i
Frame Mode 25p (25f if you like :))
That brings me adjacent to 24fps.
One frame does not make that a difference.
A possible sollution would be XM2 shot 25F,
slowed down to 24fps (including audio)
and then 3:2 pulldown into 60i.
BTW a damn good camera :).
Regards
Igor
PS: Long lives PAL !!!
WHY? I keep wondering about the hussle with NTSC's 60i format
and 24p and 3:2 and...
Maybe multi format/FPS television (set) will change that.
24 played 24, 25 -> 25, 30 ->30, 60->60. etc...
In other words some global standard.
Edited by Igor Trajkovski, 30 January 2007 - 08:50 PM.
#6 Michael Collier
Michael Collier
  • 1262 posts
Posted 30 January 2007 - 09:26 PM
For an extra thousand, you might kick yourself for not picking up the DVX-100. I have used the GL-2, owned a GL-1 and used the DVX-100 and between the three, the DVX is handsdown the best camera, even if the others had 24p. The dynamic range and quality of video is better than either of the other cameras. If you can bite the bullet on the extra grand, you'll be glad you did. The DVX quickly became my favorite pro-sumer camera for almost any application. Its worth looking into. If not, be wary of software that claims to 'mimic 24fps' because it could never perfectly replicate it, and any attempt to do so looks bad in my opinion (just my opinion, others like the look)
at least go to a rental house and do a side by side shootout and decide for yourself. all you have to waste is half a day and two mini-DV tapes.
