Can you use large PL mount zoom lenses with the M2???
#1 Chris_Burket
Chris_Burket
  • 77 posts
Posted 23 January 2007 - 02:58 PM
Does the M2 adapter have a rod support system sturdy enough for really large lenses like a Cooke 20-100, or even an Optimo 25-290??? Could you put the camera on a large Arri dovetail or how would you handle balancing the camera and lense?
#2 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 24 January 2007 - 03:52 PM
No.
The M2 uses lightweight 15mm rods, which I would never use for these lenses. In fact they probably wouldn't even fit. You need to use 19mm rod supports, and you can then use riser blocks to mount the M2 and for that matter the camera itself. A rod riser for the M2 is easy, but good luck on the camera as it will be a non-standard height adjustment. You'd likely have to have a plate machined.
#3 Chris_Burket
Chris_Burket
  • 77 posts
Posted 01 February 2007 - 02:07 AM
No.
I have used an Optimo 25-290 2.8 with an Arricam LT and 15mm stainless rods. I'm sure 19mm rods would be ideal but 15mm do work. I haven't actually used an M2 with an HVX though so I don't know what you mean by riser blocks etc... I probably need to find an HVX/ M2 package to test things out and see what's needed I suppose.
But does the M2 have the ability to use stainless steel 15mm rods and support them? What I mean is, are the rod mounts plastic, machined aluminum, etc...???
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 01 February 2007 - 12:13 PM
Chris, that's the wrong kind of 15mm rods. The rods for the M2 are based on the lightweight frontrods of a 16mm or video camera setup. They're 60mm front center to center width and 87mm from center of lens to center of rod height. The rods you must have used are the sliding baseplate variety, 100mm width and 119mm height, plus offset width centering Arri-standard v. the lightweights centered width relative to the lens.
Again, the standard rod system designed for the M2 will not work for a big lens like an Optimo. That doesn't mean that you can't use a proper sliding baseplate rod system -- be they 15mm or 19mm -- and then use risers to mount both the M2 and the camera, but the supplied rods from RedRock won't work.
#5 Chris_Burket
Chris_Burket
  • 77 posts
Posted 02 February 2007 - 01:58 AM
Ah, now I know what you mean. I remember using rods like that on an older SR2 and you are correct, big zooms could never mount on those. We were using the sliding base plate setup with the Arricam/Optimo. I guess I'll have to get my hands on a camera and adapter and do some experimenting. Thanks.
#6 Chris Keth
Posted 30 April 2007 - 03:55 PM
The rods aren't robust enough and the adapter itself would tear itself apart if the lens was not quite supported well enough. They're pretty flimsy in their construction. I wouldn't try it.
#7 andrew kuepper
andrew kuepper
  • 8 posts
  • San Diego / Los Angeles
Posted 28 May 2007 - 02:54 PM
Yes you can use PL mount lenses if you buy the PL adapter. I just completed a feature using Nikon Nikkors. Redrock sells a baseplate with rods, but I actually bought a different baseplate from ZacutoRentals out of Chicago. Their gear is made out of annodized Ferrari Red Aluminum. It's strong and looks sexy. As far as "tearing" apart, I suggest hard mounting the rig together- that is, normally the camera lens with the diopter just snugs against the M2 adapter. I ended up using a male to male ring to lock them in place. Redrock now sells such a system.
