Lighting stainless steel
7 replies to this topic
#1 Christophe Collette
Christophe Collette
  • 177 posts
  • Montreal, Canada
Posted 26 January 2007 - 10:22 PM
Hi! I have this shot to do of a girl in this kitchen, all the appliances are brushed stainless steel, it's a long steadycam shot, focus isn't on the appliances but I am quite afraid of the reflections of my lights and myself in the appliances... Any tricks, suggestions on how to light this??? I went to the location today to solve a few technical issue before the shoot and it puzzled me....
It's a very reflective surface althought it's brushed... And I can't avoid facing them in the shot...
Thanks for your ideas, help!
Great appreciated!
Christophe
#2 chris kempinski
chris kempinski
  • 75 posts
Posted 27 January 2007 - 01:26 AM
Hey,
I know only a couple things about stainless steel.
Usually try and use large soft sources, or a row
of kino with diffusion so as to make a continuous
"flare" across the entire surface that looks even and
from one single source.
We shoot the same commercial for a restaurant and
the DP always uses the steel, blasts hard light, 3 stops
over and blues up the background sources.
Oh, and a couple of black flops with a lens pointing out
between usually works for reflection.
again, best of luck.
Chris
#3 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 27 January 2007 - 07:29 AM
I don't know if you are going to have any problems to speak of. I light many situations with brushed steel for a kitchen company and I don't usually have any problems. Such metal can have problems with incident reflections but at that point it's simply moving a fixture slightly to loose the reflection. Since most all stoves are against a wall you will not have much in terms of incidence reflections. Softer sources will help as will bounce if it is an option.
#4 Daniel Madsen
Daniel Madsen
  • 201 posts
  • Boston
Posted 27 January 2007 - 07:58 AM
You light anything metallic like you would a vehicle, through reflection. Soft sources are used extensively, but think more in terms of the reflection principle, where you aren't necessarily aiming a light at the subject (pot), but lighting what you want to reflect. How do you do that? Flag off any direct light hitting the pot as to ensure that there is more light reflection in the pot than hitting it directly. A chimera will do this, but it won't be as beautiful as a sunset reflecting in the hood of an Aston Martin DB5, a pilot light reflecting In the contours of your pot or a naked women reflecting in a window looking out over the... Cameramen who specialize in this arena are called metallic cinematographers.
Dan
#5 Dino Giammattei
Dino Giammattei
  • 63 posts
  • A mile west of the crossroads and the old circus grounds
Posted 27 January 2007 - 12:06 PM
Working in the medical film making business, I've spent countless hours making pictures with steel in the shot. When shooting on location, the fore mentioned light placement and artistic use of reflections is the whole trick.. For product type shots in the studio, where detail is critical, I have come to rely on a lot of foam core and seamless paper. For your situation, which is much more involved, have you considered painting the ceiling gray? Chances are good that the ceiling will get into any downward camera angles anyway. Dropping the ceiling a few stops worth of gray paint would be a good way to control the brightest areas
just a thought
dino
#6 Jim Feldspar
Jim Feldspar
  • 288 posts
Posted 30 January 2007 - 09:13 AM
Great appreciated!
Christophe
What about dulling spray? I've heard of that. Does anybody use it? I thought that it's
intended for exactly this type of situation.
#7 Peter-Christopher I. Jorgenson
  • 10 posts
Posted 30 January 2007 - 05:43 PM
You could try, Privacy Window Spray AKA Frosted glass spray, however not sure how that would look on stainless steel or if it would damage it.
#8 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
  • Brisbane, Australia
Posted 31 January 2007 - 06:08 PM
Ive seen zip ease used to dull off shiny stainless steel.
