Mounting camera on its side
#1 Nigel
Nigel
  • 2 posts
  • Manchester
Posted 29 January 2007 - 03:36 PM
I am about to shoot a project which will be presented on portrait hung plasma screens. To film the footage I want to mount the camera on its side.
Does anyone have an idea for what sort of mounts are available, either purpose built or as adapters to place on a gel head?
#2 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 29 January 2007 - 04:19 PM
You need an L-bracket, which is an L-shaped thick metal plate which goes between the tripod and the camera. We have them available for rent.
#3 thomas-english
thomas-english
  • 99 posts
  • Steadicam Operator
Posted 29 January 2007 - 06:14 PM
put the camera sideway onto a head and tilt the head to your angle, make sure you don t want to "PAN" for your shot though.
#4 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 29 January 2007 - 06:36 PM
If it's a really low angle shot or if you have a raised flat surface to put it on, you can always lay the camera on a sandbag or cushion. Just make sure your framing is balanced and even with the horizon.
#5 Nigel
Nigel
  • 2 posts
  • Manchester
Posted 01 February 2007 - 04:00 AM
Thanks very much for the replys. My first time on here and I cannot believe I have not used it before. I think the side mounted tripod then full tilt is a good idea, allowing for PANs.
Ill post a reply when I have shot it.
Nigel
