Urgent - K3 fps dial is acting crazy!
#1 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 05 February 2007 - 10:01 AM
I am about to leave for Kangaroo Island tomorrow morning and I am bringing with me several still cameras (35mm and medium format) and the Krasnogorsk 3. Ive just ordered some Fuji Eterna 250D and this will be the first time that i will be exposing negative movie film.
However, I was playing around with the speed dial on the K3 just then - with no film loaded - and something really bizarre happened. Usually, the dial stops at the line below the 8fps marking. This time, however, the dial rotated well past that line into the region where it says 'fps' without any inclination to stop. The dial has never, ever done this before. I rotated the dial back into the 'normal region.' Now forgive me if I'm being extremely paranoid but would there be any possibility that the dot markings for the individual frame rates would no longer be accurate - or am I worrying over nothing? There's no way I can test this for sure as I am leaving for the island tomorrow morning. I ran the camera at 24fps and it sounds roughly like the same sound it makes when I usually run it at 24ps - but hard to really know for sure 100%.
Have other K3 users rotated the dial to extreme positions ? both well past the 48 and 8 fps markings but found that afterwards when viewing the results that footage shot at 24fps still looks normal ? not too fast or too slow? I hope I?m worrying over nothing.
#2 Scott Cohen
Scott Cohen
  • 34 posts
Posted 05 February 2007 - 10:14 AM
Not a problem. You can not damage the camera by doing that.
The only thing I might not do with a K3 is run it without film for a long period of time at 48fps.
Other than that, the camera is pretty bulletproof.
SC
#3 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 05 February 2007 - 05:09 PM
If you need, I can send you picture of module of speed control inside of K-3.
The disk with marks of speed have cam.
The cam to press on plate with spring from one side and pins of brake from other side
If you turn of disk with marks of speeds ( install of speed ), the cam to turn and plate will move and the pin of brake will set on other position.
The gap will change between brake disk of block of inertia speed control and pins of brake.
That's why, the block of speed control will have other speed of rotation and The camera will have other speed too.
If you can turn of disk of speed setting on full turn, this is not problem.
I can tell you simply test for adjust of speed of camera.
You need computer with monitor. The video adapter of computer can change of frequency scan of monitor.
You need set frequency divisible of 24 fps, this can be 72 Hz, 120 Hz.
You need start up of camera and see of screen of monitor on ground glass of camera.
If the speed will 24 fps, the line of frame scan will have a fixed position on the screen.
#4 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 05 February 2007 - 07:01 PM
Thankyou Olex. This is an interesting test. I note that the fps dial still comes to a stop after the '48' mark - but does also rotate all the other way around past the line below the '8' mark - does this still sound normal?
#5 ryan_bennett
ryan_bennett
  • 138 posts
Posted 05 February 2007 - 08:14 PM
Does it sound like it still works properly? Can you push it back to 24fps?
#6 Alessandro Malfatti
Alessandro Malfatti
  • 149 posts
  • Barcelona, Spain
Posted 05 February 2007 - 08:20 PM
Don't worry, on mine you can also turn the dial all the way around and it has always worked perfectly, maybe difference in design, wether you can or can't?
#7 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 05 February 2007 - 08:26 PM
Why not thread a roll of leader, or scrap film in the camera. Draw a line with a marker on the film even with some part of the camera like the gate, and shoot for exactly 10 seconds. draw another line on the film at the same spot on the camera. your lines should be 240 frames apart.
