slow fps 16mm projector?
9 replies to this topic
#1 adam berk
adam berk
  • 168 posts
Posted 08 February 2007 - 04:47 AM
Does anyone know of a 16mm projector than can be slowed down to 8fps or lower?
thanks,
adam
#2 David Venhaus
David Venhaus
  • 129 posts
  • Wiseburn, CA
Posted 08 February 2007 - 05:06 AM
An analytical projector can step a single frame at a time or other frame rates, depending on model.
Edited by David A Venhaus, 08 February 2007 - 05:09 AM.
#3 adam berk
adam berk
  • 168 posts
Posted 08 February 2007 - 05:26 AM
Any specific models come to mind?
thanks again,
adam
#4 David Venhaus
David Venhaus
  • 129 posts
  • Wiseburn, CA
Posted 08 February 2007 - 06:33 AM
thanks again,
adam
There were some made by Bell and Howell and also the Kodak Analyst II, comes to mind.
Below are links to some more modern ones.
http://www.visinst.com/Projector.html
http://www.photosoni.../projectors.htm
#5 Sam Wells
Sam Wells
  • 1751 posts
Posted 08 February 2007 - 10:30 AM
There was the Lafayette I remember.
I used (in fact I have it now, but it no longer works) an Eiki aftermarket mod similar to this one.
I had a great old Kodak 16mm Kodascope projector with a simple rheostat that was adjustable 12-24 fps.
I'll try and think of sources.
-Sam
#6 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 08 February 2007 - 03:11 PM
thanks,
adam
The many 16 mm cine projectors have fixed speed ( 24 fs ) and have AC motor 50 Hz or 60 hz an fixed transmission.
To change of gears not good ideas.
But, You can use of modules of speed control of AC motors with frequency control.
This is devices to use for production machines.
This is device control of speed of DC motor by change of frequency of output signal.
If the projector have DC motor, I can set of system of crystal synch speed control.
#7 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 08 February 2007 - 08:47 PM
Trick with that is that the machine has to then have the motor wiring separated from the lamp wiring and you run the risk of overheating as the motor also cools the lamp.
I have only seen pictures of the Lafayette ,but it seems to use the same chassis as the Kodak Analyst, which in turn is a variant of the Kodak Pagent. They were often used in sports to show game films so they do turn up from time to time.
#8 Glenn Brady
Glenn Brady
  • 328 posts
Posted 08 February 2007 - 09:04 PM
The Bolex 421 optical/magnetic 16mm projector operates at variable rates from 15 to 30 frames-per-second and also permits frame-by-frame projection. The succeeding 521 model offered remote control in addition.
#9 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 08 February 2007 - 09:43 PM
We pulled some old projectors apart and connected them to bicycles - you peddled to make them run...
Even at 1fps or so we would only get burns with B+W film - color went through fine ... you could change the shutter angle if you were really concerned ...
You just need to open it up and put a new motor in - easy!
#10 Charles MacDonald
Charles MacDonald
  • 1157 posts
Posted 09 February 2007 - 08:18 PM
I was thinking about the longevity of the machine itself, I have seen Bulbs Blister so bad in an old B&H 385 that they took out the first condenser lens. (teacher insisted on shuting down without allowing time for the bulb to cool) I am sure that the folks in Rochester did something very cleaver to get the analyst to work well.
The other though would be to slip the clutch on a victor with the still frame dowser in place. although the analyst would be the first choice as it is desined to do that all day without a sweat.
