Kinoflex
14 replies to this topic
#1 Aaron Martin (TX)
Aaron Martin (TX)
Posted 16 February 2007 - 06:18 PM
Hi all --
I'm giving serious consideration to purchasing the Kinoflex package from Pro8mm. Any one have any experience with/comments on this camera? Am I better off putting the purchase price towards on older Canon/Elmo/Nizo?
Thanks for your help.
Aaron
#2 Matthew Buick
Matthew Buick
  • 2345 posts
  • Newcastle upon Tyne, UK.
Posted 16 February 2007 - 07:06 PM
It's pretty ridiculously priced, you'd be better off buying the Zenit Quarz, (which is exactly the same camera).
#3 Antonio Bunt
Antonio Bunt
  • 134 posts
Posted 16 February 2007 - 09:36 PM
I agree with Matthew, the Kinoflex package is excessively priced at Pro8mm. The Quarz can be traced on eBay.
#4 Alessandro Malfatti
Alessandro Malfatti
  • 149 posts
  • Barcelona, Spain
Posted 16 February 2007 - 10:44 PM
I find the Quarz funny, it's like a toy Krasnogorsk 3 :D
Seriously though, I've seen it before and it actually IS a small version of the K3, everything is like half the size. But anyway, I'd totally recommend it, get it from eBay, russian cameras rule!
#5 Mike Crane
Mike Crane
  • 141 posts
Posted 16 February 2007 - 10:55 PM
The Kinoflex is nothing more than a $50.00 low end russian camera with a Pro8mm "Kinoflex" name-plate and a HUGE mark-up. Instead, you should consider using the source where Pro8mm probably got them to begin with: http://www.geocities...r_8_cameras.htm
Or, consider some of the rebuilt cameras that Spectra sells for those on a low budget: http://www.spectrafi...om/Cameras.html
good luck!
#6 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Zürich, Switzerland
Posted 17 February 2007 - 05:57 AM
I had two Quarz 1x8S-2, I spend around 15$ for each. It's the same camera as the kinoflex.
http://super8wiki.co...it_Quarz_1x8S-2
It's a funny little camera, but the lens is very soft, and the iris-mechanisme is very fragile, I droped one from about 3 inches and the iris was dead...so I got a little angry and that's what happened to it[attachment=1754:attachment]
:D :D :D
It's nice camera to collect, but I wouldn't spent more than 30 bucks on it.
If you consider a low-priced camera to film with get a canon, nizo, elmo, eumig, bolex etc... I see them all the time on fleemarkets and in secondhandshops for pretty low prices...
cheers, Bernhard
Edited by Bernhard Zitz, 17 February 2007 - 05:59 AM.
#7 Mike Crane
Mike Crane
  • 141 posts
Posted 17 February 2007 - 06:24 PM
:D :D :D
cheers, Bernhard
Why don't you try sending your camera over to Pro8 as a warranty repair?
#8 chuck colburn
chuck colburn
  • 389 posts
  • orygun
Posted 17 February 2007 - 09:28 PM
A Beaulieu 4008 ZM is a nice camera with a very god lens on it.
#9 Gerard Furber
Gerard Furber
  • 32 posts
Posted 18 February 2007 - 08:51 AM
Why do so may adverts say "Kinoflex copy" when referring to a Quarz? As I understand it the Kinoflex is an original Quarz re-labelled?
Does anyone have a spare pistol grip for one of these cameras (say from a broken one?) I would like to buy if possible.
Bernhard, do you still have the pistol grip from your now deceased camera?
Edited by Gerard Furber, 18 February 2007 - 08:53 AM.
#10 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 18 February 2007 - 12:55 PM
The name of " Kinoflex " this is special export name of russian Super 8 cine camera Krasnogorsk factory Quarz 1x8S-2.
Krasnogorsk factory make a limit delivery of Quarz 1x8S-2 cameras with name of " Kinoflex " on UK.
Quarz 1x8S-2 russian Suepr 8 cine camera with zoom lens, auto and manual control of aperture, have a few speeds and mechanical clock spring motor.
The camera have aluminium body.
The camera can work without battery, because, the battery need for light meter and auto aperture control.
The manual aperture control have mechanical levers.
The set of camera have lens for close up shooting.
I compare of Quarz with a few other Super 8 cameras and can tell, Quarz have light viewfinder.
About condition of camera.
I service and adjust of many Quarz cameras.
I don't know, what service do PRO 8.
Quarz cameras not manufacture from 1992, and stoprage long time.
Thats' why, the Quarz need service, clean, lube, test of light meter and other procedures.
I sold of Quarz cameras after detailed service only.
Any case, Quarz 1x8S-2 camera very good Super 8 camera and manu users use of Quarz cameras now.
#11 Aaron Martin (TX)
Aaron Martin (TX)
Posted 18 February 2007 - 01:01 PM
Thanks for the information on the camera.
Anyone have any "stories from the field" about using the Quarz/Kinoflex?
Aaron
#12 Bernhard Zitz
Bernhard Zitz
  • 342 posts
Posted 18 February 2007 - 03:31 PM
some people use it with anamorphic adapters. when you screw off the zoomlens you get some kind of a flat front camera with focusfree lens thats around 20mm(can't remember), then you ad your adapter...
Due to wear of the control-mechanism speeds get pretty inaccurate (faster) on older cameras.
Besides all the minuses it wrote before, I somehow like the idea of a clock spring motor in a Super8 Camera. That's why I itent to mount the lenses from a carena zoomex 7610-IM on the quarz, maybe I'll get sharper images this way. The Carena has a similar lenssystem that acts also like a focusfree prime when you take off the lens in front...
back to your first question
Yes
cheers, Bernhard
#13 David Leugers
David Leugers
  • 68 posts
Posted 18 February 2007 - 05:53 PM
Two things about the Quarz = (1)unscrew the zoom lens and clean the outside surface of the lens half that is inside the camera body and then clean the backside of the removed lens. The gunk on those two surfaces makes for most of the soft image resolution. (2) screw the auto exposure. Use a light meter and set exposure manually for happy results.
#14 Bernhard Zitz
Bernhard Zitz
  • 342 posts
Posted 19 February 2007 - 03:29 AM
my lenses were clean, results on both of my cameras were a little soft, I shot pretty open (between open and 4) maybe if you stop it further down it gets better, and contrast felt pretty flat, my other S8s give punchier contrast.
Maybe both of my Quarz 1x8S-2 had a problem. I had the same phenomenon on the Quarz DS8-3 that has the same lens(the DS8-3 was a little better but not very sharp either). I got better results on canon, bolex, eumig, even on the small and cheap ones. All this is very subjectiv, I never compared this cameras by filming charts etc... it's the subjectiv impression by looking the stuff I filmed.
#15 Gerard Furber
Gerard Furber
  • 32 posts
Posted 27 February 2007 - 06:38 PM
Hey Bernhard!
The pistol grip arrived! I am very pleased with it- it fits the camera perfectly. If it was an ebay transaction I would give you excellent feedback!
Did the IRN BRU arrive OK?
Best wishes and many thanks,
GSF :D
Edited by Gerard Furber, 27 February 2007 - 06:41 PM.
