cross processing kodachrome
#1 grant mcphee
grant mcphee
  • 93 posts
  • 2nd Assistant Camera
  • UK, Scotland
Posted 22 February 2007 - 10:24 AM
hi,
i do a bit of home processing. i've just tried to develop some kodachrome 16mm as a neg in d76 but it didnt turn out at all.
i had, what i thought was some k14 but it turns out it was k11 so was returned from the kodak lab as 'too old to process' so i thought i would develop it myself.
as it was originally intended to be shot as reversal i kept the exposure as exact as i could (i.e. i didnt over expose when shooting as i would normally if i were developing reversal as a neg).
I use d76 at 20C. i normally process negative in this for 7-8 minutes and it comes out fine. as i hadnt over exposed i thought i would push the stock so kept it in for 91/2 minutes.
when i took it out there was nothing there! just a heavy fogged green filter.
any ideas what went wrong? i know there are quite a few variables like the film being so old and not knowing where it originated. when kodak checked it could they have fogged it? or tried to develop it and it didnt work? the remjet is still there so i dont think so.
anyone tried kodachrome? if so any suggestions are appreciated.
thanks,
grant
#2 Jason Debus
Jason Debus
  • 311 posts
Posted 22 February 2007 - 11:10 AM
Processing Kodachrome is unique, you cannot cross-process it. Check this out:
Kodachrome Wikipedia
#3 grant mcphee
grant mcphee
  • 93 posts
  • UK, Scotland
Posted 22 February 2007 - 05:08 PM
[quote name='Jason Debus' date='Feb 22 2007, 08:10 AM' post='156435']
processing kodachrome is unique, you can't process it yourself but you can cross-process it yourself. it's forms an image in the same way as any other film when light hits it. so using any universal developer, like d76 should produce a negative monochrome image. its the colour aspect of kodachrome which is unique. in theory.
has anyone developed their own kodachrome?
thanks
#4 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 23 February 2007 - 01:57 PM
Since KODACHROME film does not have incorporated dye-forming couplers, processing in any other color process will yield no image. Processing in a B&W negative process will yield a B&W silver image.
#5 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 23 February 2007 - 02:16 PM
Interesting...anyone tried this?
#6 grant mcphee
grant mcphee
  • 93 posts
  • UK, Scotland
Posted 23 February 2007 - 06:19 PM
yes, me!
i was asking why i didnt get an image using a b+w developer (d76). I'm usually pretty successful when home processing (apart from a few mistakes on my own part) but couldnt seem to get the hang of k14 (though i think it was k11 i tried). I think that it must have been fogged due to age.
anyone else tried? i think you get a green mask with d76.
cheers
#7 Richardson Leao
Richardson Leao
  • 363 posts
  • Stockholm, Sweden
Posted 23 February 2007 - 07:50 PM
yes, me!
cheers
hi, i tried k14 using d19 (as a negative it works after playing with the anti-halation layer). It's very dense though but cool.
#8 David Venhaus
David Venhaus
  • 129 posts
  • Wiseburn, CA
Posted 23 February 2007 - 09:29 PM
I did some tests a few years ago with some kodachrome II process k-12, expiration date of march 1964. Developed it in Dektol. Initial tests were very fogged. Reduced development time to lower then the fog level. Ended up only being able to shoot the sun with star cross filter, as it was the only thing capable of exposure above base fog, then slight bleaching, just for effects. The kodachrome was d-8, but not split then printed on 7302.
#9 grant mcphee
grant mcphee
  • 93 posts
  • UK, Scotland
Posted 24 February 2007 - 04:15 AM
thanks david. thats interesting to know. i'll try a few tests with reduced time and see what happens. i think though, i'll just use the remaining rolls (all from same batch unfortunately) as leader. or for scratching onto
