Revere 16mm
21 replies to this topic
#1 Joe Smith
Joe Smith
  • 24 posts
Posted 02 March 2007 - 06:36 PM
I believe this takes single perf film right? Is it worth the trouble? The magazine film is readily avaliable and was wondering if any one knew about these. ThanksPosted Image
#2 Matthew Buick
Matthew Buick
  • 2345 posts
  • Newcastle upon Tyne, UK.
Posted 02 March 2007 - 06:58 PM
It most likely takes double perf. :)
And I'm afraid you'll have to change your display name to your real name, it's the forum rules you see.
#3 Joe Smith
Joe Smith
  • 24 posts
Posted 02 March 2007 - 07:03 PM
if you could only still get double perf :angry:
#4 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 02 March 2007 - 08:41 PM
Magazine film is Double perf, and is wound inside out, the film goes over The same sproket twice and the magazines only are 50 ft long.
If you want to use it you will have to acquire some mags and spend a lot of time winding film in the dark, alther you buy whatever stock you want as a special order.
Many of the 100 ft spool cameras can take single perf, or can be modified to use it.
I have bought of couple of the B&H mag cameras just to steal their lenses and finders.
#5 Joe Smith
Joe Smith
  • 24 posts
Posted 02 March 2007 - 10:57 PM
so there really is no point in having regular 16mm.
#6 Charles MacDonald
Charles MacDonald
  • 1157 posts
Posted 03 March 2007 - 08:14 PM
regular 16 is fine for many applications, but the magzine camera were intened for home movie use in the early 1950's. Their are so many 100Ft spool cameras, many of which will accept or can be simply modified to use modern regualr 16mm stock taht it is probaly not worthwhile thinging about the mag cameras, whith the exception of uses like Crash and Helment monted cameras where the smaller size of a magazine usnit may make the film supply hastle less combersom.
If you buy fresh sotock, you will get siingle perf, which can be used for both Regular 16mm format and also super 16mm format depending on the camera. A magazine can only be loaded with double perf stock which is a special order item, unless you modify both the magazine and probaly the camera. You will still have all the conprimises of the amgazine design, (presure plate in the mag, 50FT max load)
A keystone 100 ft load camera is actually very competent if it is cleaned and adjusted, and can be found ready to take single perf. They often sell for under 40 dollars on e-bay. A filmo, or a B&H 240 is a very competent camera for generaly under $150 US. most again set up for single perf stoock and regualr 16mm format.
#7 Joe Smith
Joe Smith
  • 24 posts
Posted 04 March 2007 - 12:07 AM
thanks for the info :) I actually just won a keystone a7 or 9 (don't remember which one) on ebay. So it looks like i might be modding the keystone :). And would i be able to use a 50mm olympus lens with this? (with a cmount to olympus adapter)or would it vignette?
#8 ryan_bennett
ryan_bennett
  • 138 posts
Posted 04 March 2007 - 12:28 AM
You can find 50 foot carts of 16mm on ebay and also at java photo I believe.
You can get double perf, just order directly from kodak or fuji and specify it. I never had a problem but if you're serious, just upgrade your camera or rent, it's easier.
#9 Joe Smith
Joe Smith
  • 24 posts
Posted 04 March 2007 - 12:34 AM
im not gonna worryh about the magazine camera, seems like more trouble than its worth. I'm looking forward to converting the keystone to s16.
#10 Joe Smith
Joe Smith
  • 24 posts
Posted 04 March 2007 - 10:19 AM
also there is no places to rent in my area :(.
#11 Charles MacDonald
Charles MacDonald
  • 1157 posts
Posted 04 March 2007 - 08:22 PM
The keystone may be set up for single or double, I have one of each. Mine are all waiting for a good cleaning/ lubrication as I am not sure if they are close to speed.
A file and so patience is probaly want you need to convertone for super 16 , although I havent looked to see if the shutter is big enough to cover a filed out frame.
#12 Joe Smith
Joe Smith
  • 24 posts
Posted 04 March 2007 - 08:40 PM
once it comes in the mail ill post some pictures. Hopefully it won't be too hard to convert.
#13 Michael Carter
Michael Carter
Posted 04 March 2007 - 09:05 PM
when you have two, one can have the top teeth filed off the drive wheel. The drive wheel can be interchanged, then, with other ones so you don't need to do it again.
If you search on my posts here you will find close up pictures inside the 50 foot magazines.
Michael Carter, studiocarter
#14 James Erd
James Erd
  • 187 posts
  • Palo Alto, CA
Posted 04 March 2007 - 09:29 PM
I've never had any problem getting double perf in 100' daylight loads for my Bolex. Though it's been a couple of years since I last bought film. Did they really stop making it?
#15 Joe Smith
Joe Smith
  • 24 posts
Posted 04 March 2007 - 11:20 PM
no longer on any sites, i guess you have to call kodak of fuji
#16 Michael Carter
Michael Carter
Posted 05 March 2007 - 11:45 AM
I bought a case of empty mags on ebay. The seller is on there a lot. Film may be possible. Loading is easy enough.
I shot negative, 4-5 rolls of it and had a fully timed print made. It is great. Black & White. I love those little cameras.
http://www.alangordo...cam16_mags.html
Java also sells it.
There is no reason why anybody can't load them. I had to UNload in a bag and spool them inorder to get a lab to process them. They did after film was on spools.
Michael Carter
#17 Michael Carter
Michael Carter
Posted 05 March 2007 - 04:25 PM
And here are magazines for you to load:
http://cgi.ebay.com/...1QQcmdZViewItem
ebay magazines
and look here:
java film
http://www.athens.ne...a/filmpage.html
If someone knows about getting film, I'm ready to buy some, too. Please post info here? That would be bulk film to wind down into small loads for the magazines.
thanks,
Michael Carter
Edited by Michael Carter, 05 March 2007 - 04:28 PM.
#18 Michael Carter
Michael Carter
Posted 05 March 2007 - 04:44 PM
Never mind about the film. A Kodak film pdf catalog from 12/2006 has lots of 2R double perf film for sale. Any of them could be loaded into the little magazines.
Michael Carter
#19 Charles MacDonald
Charles MacDonald
  • 1157 posts
Posted 05 March 2007 - 08:30 PM
But check the footnotes - only a few of them are kept in stock, the minuimum order can be rather impressive depending on where you are located in the world. I belive that their are few stocks that you can order a couple of 100 ft rolls double perf anymore.
#20 Michael Carter
Michael Carter
Posted 05 March 2007 - 09:05 PM
I'd want a large roll to put onto many little cores. 100 foot spools wouldn't do for this purpose. It would be a rather larger size decision, however.
