Converting an RCA FR-35B 35mm projector to xenon
#1 Zachary Vex
Zachary Vex
  • 208 posts
Posted 09 March 2007 - 08:15 PM
My RCA FR-35B has a 1kw halogen light that just isn't cutting it for projecting on a 6-7' screen. I need a lot more light... has anyone ever converted a 35mm projector to xenon? Is there a consumer projector that has a bright xenon bulb and power supply (perhaps a slide projector or 16mm projector) that I could pull the light and p.s. out of for use in my projector? Anyone have any other ideas?
#2 chuck colburn
chuck colburn
  • 389 posts
  • orygun
Posted 09 March 2007 - 09:08 PM
Zachary,
I've found that most anything can be built (for a price) but what I want to warn you on here is about Xenon lamps. These are very high pressure bulbs and are capable of exploding at any given time, particularly when they are hot. Read up on it if you don't already know. Ask a local projectionst and he will (hopefully) show you the protection gear he wears when changing a bulb out. Be carefull.
Chuck
#3 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 10 March 2007 - 07:54 PM
Hey Zach,
I used to repair the heads and lamp housings at the Cinema 6 in Southaven, MS. I'd recommend getting the complete lamp housing off of an old projector. They have to draw air properly (evenly) with a fan system or the lamps will burn out and even pop on you. Just sticking a mount in any old housing is not recommended. Since the heads grind up sooner than the housings, you'll probably find one but at what price I can't say. That's just a humble opinion. Good luck on it.
#4 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 11 March 2007 - 04:55 AM
You'll also need a rectifier (xenons are DC units) and some kind of "striking circuit" (they ned to be "lit" by passing high voltage through them to strike up).
#5 Charlie Peich
Charlie Peich
  • 247 posts
  • Chicago
Posted 11 March 2007 - 08:14 AM
Zach,
Check out this forum Film-Tech. These are the guys running the 35mm projectors in the theaters around the world. A vast amount of knowlege on 35mm projectors available. Free to join, then ask the forum, I'm sure there is someone there that can answer your question/knows your model of RCA projector.
#6 Zachary Vex
Zachary Vex
  • 208 posts
Posted 11 March 2007 - 06:44 PM
Yeah, I've been posting there for a few days.
